MUNDORF N300 Self Coil Zero Ohm 1mH
Self Mundorf Zero Ohm Coil N300 1.0mH
Reference : 1694
134,70 €tax incl.
112,25 € tax excl.
The zero ohm "Zero Ohm Coil" (ZOC) coil is a transformer coil.
It is made of FERON, a material of high quality which limits the distortions induced as much as possible.
In the ZOC the central space is calibrated and adjusted by hand between the 2 laminar cores (one in L shape and one in E shape).
The volume of the central space determines the inductance of the coil and requires a lot of precautions in the manufacturing process.
It should not be too small, otherwise saturation effects could occur at high load.
These coils are recommended for filtering bass speakers.
Their low impedance makes it possible to improve the impulse response (Loudspeaker better held).
Characteristics:
  • Tolerance: 5% Maximum
  • Core: Feron
  • OFC 99.99% pure copper
  • Dimensions of a coil Zero Ohm N106: 106x94x88mm
Colissimo - TNT - SoColissimo
