ALLO BOSS PLAYER Allo Boss DAC V1.2 + RPI 3 B+ + Case + Micro SD 8Gb + Power Supply
ALLO BOSS DAC PCM5122 32Bit / 384kHz with 2 clocks Master Clock I2S
Reference : 11987
149,00 €tax incl.
124,17 € tax excl.
Instead of 199,60 €
Shipping from France
Billing in France
Technical support in France
Pack content
ALLO BOSS PLAYER PACK
Boss DAC V1.2 (PCM5122) / Raspberry Pi 3 B+ / RPI + Boss Case Black / Micro SD 8GB / Alimentation
A complete pack for a (almost) ready-to-use system
This pack allows you to have all the elements to mount your own DAC. Made up of a Boss DAC, a Raspberry Pi 3 B+, a suitable case, a 8Gb Micro SD card and a power supply, this is an efficient, versatile and affordable solution.
DAC ALLO Boss V1.2 PCM5122 32bit / 384kHz
The BOSS de Allo DAC isa converter with PCM5122 DAC decoding signals up to 32bit / 384kHz. It allows digital processing in high-end I2S format. Thanks to its own Masterclock clock it recovers the digital signal DATA, generating only a very low noise drift. So that the Raspberry Pi no longer sends its clock to the DAC but only the data, you simply switch to I2S master mode on your software player.
The DACBoss also offers a unique design by separating the voltages on 3 channels using 3 filters by self shielded and capacitors.
  • A channel for the digital stage
  • A second for the analog stereo stage
  • The last one for the 2 NDK clocks
The power is filtered again by the LDO regulators, in order to reduce the noise even further.
Allo Boss DAC
Raspberry Pi 3 Modèle B+
Raspberry Pi
The pack incorporates the now well known Raspberry Pi 3 B+, in order to directly transfer the data to the Boss DAC. It is equipped with a CPU 64 bits ARMv8 1.2Ghz Chipset, the management of the 802.44 b / g / n wireless LAN, Bluetooth 4.1, 1GB LPDDR2 memory and full connectivity for all your uses.
DAC Boss + RPI Case
This case has been specially designed to accommodate the Raspberry Pi and Dac Boss. In black acrylic, it effectively protects your converter from both dust and shock, while giving it a sober and elegant design.
DAC Boss + RPI Case
8Go Micro SD Card
This 8Gb Class 10 Micro SD card with adapter will allow you to install the OS of your Raspberry Pi.has a read speed of 48 MB / s and a write speed of 12 MB / s.
Micro Sd
Power adaptaters
This 5V 3A DC power supply is compatible with a mains voltage of 100 to 240V AC. It is accompanied by a jack to micro USB adapter, and adapters for USA and UK plugs.
Alimentation
Technical Characteristics
Boss DAC
ConverterPCM5122
Signal to Noiser Ratio112dB
THD+N-93dB
Dynamic Range112dB
RMS Output Level2.1Vrms
Crosstalk between channels-110dB
Sampling rate8kHz à 384kHz
Voltage regulatorsLT3042
Clocks2x Ultra Low Jitter
Raspberry Pi 3 B+
SoCBroadcom BCMC2837BO
CPUCPU 64 bits ARMv8 1.4Ghz
Wifi802.11n
Bluetooth4.1
Ethernet RJ45 connectorx1
GPUBroadcom VideoCore IV @400MHz
MemoryLPDDR2 1Go
Video outputHDMI
Audio outputStereo Jack 3.5mm
5.1 output on HDMI
USB connectorsx4
Case
MaterialAcrylic
Spacers supplied-
Micro SD
TypeClass 10
Capacity8Go
Reading48Mb/s
Writing12Mb/s
SD adapter1x supplied
Power supply
Compatibility100 to 240V AC
Output5V 3A DC
Jack DC output diameterExternal 5.5mm
Internal 2.1mm
Jack adapter to Micro USB1x
USA adapter1x
UK adapter1x
InputI2S
DAC / ADC ChipPCM5122
Max sampling rate384kHz
Good service
Very good product for the price. Arrival in time and excellent customer service after arrival
This review has been posted for ALLO BOSS PLAYER Allo Boss DAC V1.2 + RPI 3 B+ + Case + Micro SD 8Gb + Power Supply
