SUPTRONICS X450 Class D Amplifier DAC Module ES9023 2x TPA3116D2 2x100W 4 Ohm 24bit 192kHz
This digital/analog conversion and amplification module for Raspberry Pi connects directly to the GPIO of the Raspberry Pi, allowing simple operation without special wiring. Although compact, the module integrates two TPA3126D2 amplifier chips capable of developing a power of 2x100W under 4Ω.
4.0 / 5
Reference : 14334
69,90 €tax incl.
58,25 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
SUPTRONICS X450
X450 Module DAC Amplificateur Class D ES9023 2x TPA3116D2 2x100W 4Ω 24bit 192kHz
This digital/analog conversion and amplification module for Raspberry Pi connects directly to the GPIO of the Raspberry Pi, allowing simple operation without special wiring. Although compact, the module integrates two TPA3126D2 amplifier chips capable of developing a power of 2x100W under 4Ω. A significant energy reserve, supported by a high efficiency Class D structure. The amplifier chips are covered by a heat sink to dissipate the heat generated. An ALPS RK163 potentiometer allows precise adjustment of the volume level.
The digital/analog conversion is performed by an ESS ES9023 DAC chip supporting sample rates up to 24bit 192kHz and providing a dynamic range of 112dB.
On the connector side, a 3.5mm stereo jack is also available as an input, allowing you to connect an external source. There is also a PH 2.0mm 4 pins connector to connect an ON/OFF button, an XH 2.54mm connector to enjoy a 5V output and finally, an infrared receiver to associate a remote control (not included).
The module is powered over a wide voltage range, from 6 to 26V DC. The power supply circuit integrates an ultra low noise regulator (output noise less than <10µVrms) and a high performance DC converter in order to deliver a clean and stable electrical signal to all circuits. The power supply of the module is also converted to 5.1V 3A to supply the Raspberry Pi directly.
The Raspberry Pi is sold separately.
Do not power the Raspberry Pi when using the X450 module. The power supply of the X450 is converted to supply the Raspberry Pi with 5V.
Pinout GPIO 2x13 pins
X450 Module DAC Amplificateur Class D ES9023 2x TPA3116D2 2x100W 4 Ohm 24bit 192kHz
Product typeDAC
Amplifier
DAC ChipES9023
Amplification chip2x TPA3116D2
Amplification classClass D
Output power2x100W @ 4Ω, 21VDC
Supported sampling ratePCM up to 24bit 192kHz
InputsGPIO (Raspberry Pi sold separately)
Stereo Jack 3.5mm
Other connectorsPH 2.0mm 4 pins connector for power switch
XH 2.54mm connector for 5V output
OutputSpeaker terminal
Jack 3.5mm input level2Vrms
DNR112dB
PotentiometerALPS RK163, Ø6mm, notched
IR Receiver
Power supply6V-26VDC ≥3A via Jack DC 5.5/2.5mm or screw terminal
(the power supply of the module is converted to 5V 3A to power the Raspberry Pi)
Dimensions87 x 56mm
GPIO usedLRCK - IO19
BKC - IO18
DATA - IO21
IR - IO26
AMP Mute - IO22
Weight170g
Package1x X450 board
Screws and spacers
2 reviews
ampli et DAC de qualité
J'ai acheté 3 suptronics X450 pour des systèmes audio autonomes synchronisables que j'utilise sur du spectacle vivant en extérieur.
Couplés à des yamaha S15 d'occases la qualité est au rendez-vous.
Le ratio encombrement/qualité/puissance est excellent pour mes besoins.
J'ai une voie défaillante sur un potentiomètre de volume mais ayant meulé l'axe pour le raccourcir je ne peux pas en vouloir au fabricant.
Seul bémol: l'ampli bascule directement sur l'entrée auxiliaire jack 3,5 lorsqu'on introduit une fiche, le choix de l'entrée (GPIO ou jack 3,5) pourrait être sélectionnable par un jumper (ou autre) et donc pilotable par le raspi (amélioration que je vais certainement réaliser avec un transistor).
La plage de tension utilisable est top (6V - 26V), je fonctionne sur batteries lithium 24V qui chargées à fond dépassent les 29V, l'ampli ne coupe que l'étage d'amplification vers 28,7V pour se protéger sans couper l'alimentation du raspi ce qui est rassurant.
Je n'ai pas testé le X450 sur un système hifi et n'ai pas les oreilles affutées pour cela (je construit de la machinerie et ne suis pas ingénieur du son).
Comme d'habitude Audiophonics propose du matériel de qualité, packaging impeccable, expédition rapide.
Merci Audiophonics.
This review has been posted for SUPTRONICS X450 Class D Amplifier DAC Module ES9023 2x TPA3116D2 2x100W 4 Ohm 24bit 192kHz
Efficace, peu encombrant et qualité
Je n'ai pas l'oreille fine de l'ingénieur du son. Mais en comparaison avec d'autre type d'ampli que j'utilise pour des systèmes de diffusion autonomes sur batterie celui ci est très satisfaisant. Alimenté en 24V et testé sur différents modèles d'enceinte "ça envoi", pas de souffle et ça tient dans la main. Je vais lui ajouter une ventilation car ça chauffe pas mal. Bémol: lors du branchement d'un jack 3,5 sur l'entrée auxiliaire l'ampli bascule automatiquement sur celle-ci, je vais tenter de résoudre cela par mes propres moyens.
This digital/analog conversion and amplification module for Raspberry Pi connects directly to the GPIO of the Raspberry Pi, allowing simple...
