CONNEX SMPS2000RS Switched Mode Power Supply Module 2000W / 48V
The SMPS2000RS switched-mode power supply is a very high-efficiency model capable of developing a nominal power of 2000W in a small footprint. It will therefore be able to deliver 2000W continuous power and up to 2600W peak power with a suitable heat sink.
By buying this product you get 32 loyalty points
Reference : 14712
329,00 €tax incl.
274,17 € tax excl.
Shipping date: 22-07-2025.
Connex SMPS2000RS
Connex SMPS2000RS Module d'Alimentation à Découpage 2000W 48V
The SMPS2000RS switched-mode power supply is a very high-efficiency model capable of developing a nominal power of 2000W in a small footprint. It will therefore be able to deliver 2000W continuous power and up to 2600W peak power with a suitable heat sink.. The model supplied delivers 48V output.
The main feature of this power supply is the absence of heat sinks for both power switches and rectifier diodes. The amount of EMI is lower than on any conventional power supply and it could be compared to a regulated linear power supply. Its small size and considerably reduced weight allows the SMPS2000RS to be installed in many enclosures.
In addition, the module incorporates an overcurrent protection that limits the output current to approximately 130% of the maximum peak power, i.e. approximately 2600W. This power supply is suitable for both Class AB and Class D/T amplifiers.
Meaning of abbreviations on SMPS power supplies
QR, R : SINGLE or DUAL power supplies with LLC classic resonance filter for Class AB or D amplifiers. The SMPS R are characterized by their very good price/performance ratio.
RE : SMPS power supplies with differential outputs and multiple resonant filter voltages, including a LLC filter with low noise EMI filter (with CLC filter at low ripple output). Suitable for high-end amplifiers in Class AB, D or T. Advantageously replaces conventional linear power supplies. (Generally suitable for TA2022, TDA8920, TDA8950, IRS2092 amplifiers).
RS : SMPS power supplies close to the RE but with resonant filter Single Rail Output featuring a LLC filter with low noise EMI filter (with CLC filter at low ripple output) Suitable for high-end amplifiers in Class AB, D or T. Advantageously replaces conventional linear power supplies.
RxE : The top of the range SMPS 600W, 800W and 2000W, featuring latest generation LLC resonant filters (with CLC filter at low ripple output) with high-end FET transistors. Specially recommended for high-end Class D amplifiers (IRS2092, Hypex, CXD). Can also be suitable for classic Class AB amplifiers.
Product typePower supply
Power supply typeSwitched Mode Power Supply (SMPS)
Output voltage48V
Input voltage196-254V AC
Aux output±12V
Very high efficiency power supply-
Low EMI electromagnetic radiation-
Advanced protection system-
Rated power2000W
Maximum power2600W
Dimensions120 x 200 x 40mm
Weight920g
VisualsPhotos not contractual
InputPCB Connector
OutputPCB Connector
Output voltage (V)48.0
Output current (A)NC
Input voltage (V)220.0
Input voltage (V)250.0
Input voltage (V)230.0
Input voltage (V)210.0
Input voltage (V)240.0
Input voltage (V)200.0
Power SupplySMPS
The SMPS2000RS switched-mode power supply is a very high-efficiency model capable of developing a nominal power of 2000W in a small footprint. It...
