By buying this product you get 26 loyalty points
Switching Mode Power Supply Board 2x64V 12V 3.3V +/-18V +/-25V 1500W
Micro Audio's SMPS1K-PFC is a high-performance regulated switched-mode power supply module specifically designed for audio applications requiring high reliability. It's compatible with Hypex SMPS1200 pinout, and can be used to supply 2 Purifi modules.
The module integrates power correction and PFC regulation, ensuring a low voltage drop at the output over the entire load curve. The power supply also benefits from advanced thermal and overcurrent protection as well as AC line loss detection to immediately shut down the power supply in the event of a disconnection.
The module has a 2x64VDC main output and auxiliary outputs. There is a 12VDC, 3.3VDC and +/-25VDC unregulated output, as well as a +/-18VDC regulated output.
The SMPS1K-PFC also provides an input for an ON/OFF switch, a DC Error input and a Delay Out output.
The power supply is delivered with all the necessary connectors and cables, as well as an optional module for filter capacitors (sold separately).
Product type | Switching mode power supply |
Input | 110-250VAC |
Outputs | 2x 64VDC 12VDC 3.3VDC ±18VDC regulated ±25VDC |
Other connectors | Standby input DC Error input Delay Output |
Dimensions | 250 x 123 x 66mm |
Mounting holes spacing | 241 x 72mm |
Weight | 1370g |
Input | PCB Connector |
Output | PCB Connector |
Output voltage (V) | 2x64 |
Output voltage (V) | 3.3 |
Output voltage (V) | 12.0 |
Output current (A) | NC |
Input voltage (V) | 220.0 |
Input voltage (V) | 250.0 |
Input voltage (V) | 120.0 |
Input voltage (V) | 130.0 |
Input voltage (V) | 190.0 |
Input voltage (V) | 210.0 |
Input voltage (V) | 240.0 |
Input voltage (V) | 110.0 |
Input voltage (V) | 230.0 |
Input voltage (V) | 150.0 |
Input voltage (V) | 200.0 |
Power Supply | SMPS |
