Power on and Delay Softstart Board for Amplifier
Power on and delay softstart board for amplifier
This board controls amplifier ignition. It provides stand-by, soft-start, timer and thermal protection functions. It also limits the current draw through the power supply capacitors and transformer during switch-on.
Reference : 10662
18,90 €tax incl.
15,75 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
The module connects directly to the 220V input. If no load is connected, you may find 220V at the output (capacitor in series). When you activate the softstart, it powers your amplifier through the thermistors. After a second, the relay engages and connects the output directly to 220V.
This board does not suppress ignition "pop". In this situation, an HP timer card is required.
Characteristics :
  • Maximum relay current: 20A
  • Operating module up to 1000W max.
  • Approx. 1 sec. delay
  • Current-limiting thermistors (softstart)
  • Mounting holes spacing: 60mm x70mm
  • Screws, spacers and wiring included
  • Dimensions: 87*695*30mm
  • Weight: 100g
2 reviews
Parfait pour un ampli de forte puissance
Ce module est parfait, et fonctionne très bien sûr mon amplificateur de puissance équipé de 2 transfos de 500VA.
This review has been posted for Power on and Delay Softstart Board for Amplifier
Carte ok
Tout fonctionne correctement. Le schéma fourni en description par audiophonics est appréciable. Livraison toujours Ok après plusieurs commandes.
This board controls amplifier ignition. It provides stand-by, soft-start, timer and thermal protection functions. It also limits the current draw...
