Selecteur audio 1 to 2 reversible for speaker / amplifier Black S
2 Audio Selector 2 IN 1 OUT / 1 IN 2 OUT for speaker / amplifier Black
Reference : 13232
79,00 €tax incl.
65,83 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
Audio selector
1 input / 2 outputs (reversible) to speaker
Audiophile selector switch amplifier to speaker
This device is installed directly after a power amplifier or integrated amplifier. It has two outputs and each can be connected to a (passive) speakers set .
A toggle switch on the front panel selects the active output. The function is to alternate speakers without having to redo the connections. In other words, it allows alternating speakers while benefiting from a fixed installation with permanent cable connections. It means many possibilities to test several speakers, make your versatile sound-installation ... etc.
Simple and effective circuit
The device's internal wirings are robust and reliable. Silver-plated OFC 2.5mm²  conductor ensure a clean and clear signal on input as well as output.
The ON / ON switch in charge of selecting the target speaker is an electronic component designed for high powers (10A 250VAC) tolerance.
The device is mounted on soft rubber stands to reduce vibration and scratches on the housing.
Switch speaker amplifiers
Terminal speaker audiophile grade
Quality speaker terminals
This selector has one input and two outputs, all of them are gold plated speaker terminals.
Even if this configuration needs 12 connectors, the wiring of the device has been thoroughly done to allow the device to stay small and easy to install.
Because of the many connectors and to avoid false contacts and signal loss of any kind, this speaker selector embarks qualitative terminals, fully removable, compatible with bananas plugs and easy to wire, even when using bare wire.
Reversible switch
By its construction, the audio selector can be used in both directions.
That is to say, one can use the device for connecting an amplifier to two sets of speakers used in alterance (conventional use).
However the opposite is also possible: connect two amplifiers in a single speaker system. In such a configuration, the switch will determine which of the two amplifier is active.
In one way or another, this type of device does not exempt the usual precautions when it comes to the use of an amplifier and one (or more speakers). It is imperative to put off all concerned devices before switching anything.
inverting input audio output selector
Two sizes available
Compact Audio Selector or imposing
Depending on the needs of your installation this audio selector comes in two sizes.
The larger sized one has larger terminals that can accept a larger contact surface in the case of using a high-precision cable.
However, the smaller size (the one we are now discussing) has exactly the same functions while being significantly more compact.
TypeAudio source selector
Power supplyPassive
Inputs1 stereo analog inputs (speaker terminal x2)
Outputs2 stereo speaker outputs
Mode selectionLever switch
HousingAluminum
Dimensions162 x 62 x 129mm
Weight715g
InputSpeaker terminals
OutputSpeaker terminal
10 reviews
Répartiteur de haute qualité pour enceinte sur 2 amplificateurs.
Très content de ce petit boitier que je partage avec une paire d'enceinte principal, un ampli Hifi , et un ampli HC.
La sélection sur l'interrupteur de ce petit boitier est génial. Moyen facile de changer les entrées sans avoir à déplacer les connexions des haut-parleurs. C'est vrais que cela peut paraitre un peu cher mais quel facilité simple et efficace.
Pour ma part j'ai trouvé le son un peu criard sur mon système, mais je m'y attendais, car j'ai le même problème pour avoir déjà eu l'occasion de mettre en tests des câbles sources ou d'alimentation en placage argent !
Comme le boitier en aluminium est d'une grand facilité de démontage, (8 vis) , et que j'adore bricoler) , j'ai juste changé les 12 petits câbles interne de 13cm +/- en argent, par les même câbles que mes enceintes à l'ampli (en 4mm OFC) ainsi que 24 cosses à sertir (jaune 2.5 à 6 mm²), et le tour est joué. Les son est quasi à l'identique comme avant. Que du bonheur :)))
Merci à Audiophonics pour l'emballage très correcte, et la rapidité de l'envoie en Belgique (4 jours). A très bientôt.
This review has been posted for Selecteur audio 1 to 2 reversible for speaker / amplifier Black S
Excellent
Utilisé pour raccorder deux paires d enceintes Yamaha pianocraft (une paire côté bureau et une côté lit) sur un seul ampli yamaha E810 : aucune perte de musicalité audible avant - après.
Très facile d’utilisation
Le petit modèle est largement suffisant et aucun problème place pour des connexions avec des câbles de 2x2,5
Encore un excellent produit Audiophonics !
Encore un excellent produit Audiophonics, l'assertion constituant, de fait et à l'évidence, un parfait pléonasme ;)
Plus sérieusement, ce sélecteur de sources très bien construit remplace, bien utilement, un sélecteur de sources Dynavox qui aura tenu moins de quelques mois avant que le knob de sélection de sources commence à faire des siennes (perte d'une voie sur l'une des deux positions possibles).
Au vu de la qualité de construction du sélecteur de sources Audiophonics, il m'étonnerai beaucoup qu'il me soit nécessaire d'avoir à m'en séparer prochainement.
Bravo - one more time - Audiohonics ;)
Excellent produit !
Mon objectif était de pouvoir utiliser mes enceintes principales stéréo autant en écoute "audiophile" que pour le HC en ayant 2 systèmes d'amplification distincts. Ce sélecteur me permet donc de commuter vers l'ampli HC ou vers l'ampli Hifi en fonction de l'usage du moment. Une chose est sûre : aucune perte audible en faisant transiter le signal audio en sortie HP via ce sélecteur. La qualité de construction est digne des appareils audio de qualité avec un beau boîtier en alu épais et de superbe bornes d'entrée et sortie HP. Le commutateur est franc et ne génère aucun bruit parasite en passant de A à B et inversement. En conclusion : appareil tout à fait recommandable pour son usage.
Très bon produit
Simple, efficace (commutation sans parasites).
