Source selector RCA 4 to 1 / reversible
Source selector RCA 4 entries
4.9 / 5
Reference : 13228
54,90 €tax incl.
45,75 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
Source selector 4xRCA IN / 1xRCA OUT
Source selector passive
This device can connect multiple analog sources to your preamplifier, your integrated amplifier or your active speakers.
Its function is to allow a permanent connection between multiple sources (up to 4) and a single amplifying device.
Once the source selector integrated in a complex audio system, just use the knob to select the active source.
It can also work in the other direction, sending a source to several amplifiers for example.
In addition to the comfort of being able to change source without connecting/disconnecting anything, this type of device is particularly useful for increasing the durability of the mechanical parts of the installation (connectors, plugs, cables), since these will be less prone to frequent handling.
Large knob for selection
The source selection is done through a single rotative knob on the front panel.
This knob drives a mechanical switch mounted on PCBs for switching the signal.
A digital marking paired with the RCA inputs facilitates the identification of the active source.
This type of completely passive assembly is valued for its very low coloration of the sound as long as correct cables with moderate length are used .
Selector passive source
RCA connectors source selector
RCA Connectors
The four stereo inputs and stereo output are RCA ports.
The connectors are gold plated and ensure good conductivity of the signal.
Each RCA port is welded individually to the PCB to prevent the different sources from receiving noise from other sources.
The selection must be made with the amplifier switched off to avoid switching noises.
The ground between the inputs and with the output are common.
TypeSource Selector
passiveYes
inputsStereo RCA X4
ExitsStereo RCA X1
Mode selectionknob
HousingAluminum
Dimensions168 x 53.5 x 106 mm
Weight610g
15 reviews
Very good quality product
Connected to pre out of my amp and delivers the signal to an headphone amplifier as also to a powered subwoofer (with 5m cable).It works without any noticeable problem.It actually seems as there is not exist in the chain! Great stuff.Absolutely recommended!
This review has been posted for Source selector RCA 4 to 1 / reversible
Bon sélecteur de source.
Un bon sélecteur de source, assez massif, mais qui n'est pas donné. Pas d'effet sensible sur le signal, au sens positif: c'est propre, sans atténuation. Utilisé pour switcher le signal de mon DAC SU-6 (très bien, Audiophonics aussi) entre preamps à tubes ou en direct sur mon Pioneer A30-K
Excellent sélecteur de sources
J'utilise un seul sub pour mon ampli Marantz HC et également pour mon ampli hifi Audiophonics.
Il me fallait donc un appareil me permettant de passer de l'un à l'autre sans difficultés.
Sur les bons conseils de David Aubert (comme d'habitude), j'ai commandé ce sélecteur de sources.
Je passe d'un ampli à l'autre sans aucuns soucis. J'ai juste a régler le crossover de mon caisson clos a chaque utilisation.
Excellente finition.
Un très bon appareil a un prix défiant toute concurrence.
parfait
rien à dire. C'est simple et bien fait
Très bon produit, belle finition, sans fioriture inutile. Le câblage interne est soigneusement réalisé. Prix très compétitif !
