Classique mais indispensable pour des connexions de qualité, sur nouvelles enceintes comme sur de vieux modèles aux borniers sous-dimensionnés.
95x75mm
These speaker terminal blocks have screw-in connectors that also accept banana plugs. The 4-terminal design will allow you to bi-wire and therefore enjoy the benefits of this type of link. The terminal block contacts are made of alloy copper with Gold plating to ensure both good conductivity and resistance to oxidation. At the back of the plate is a foam seal, to seal the chamber of the enclosure.
Spécifications | |
Contacts material | Alloy copper |
Plating | Gold |
Drilling diamter | 95x75mm |
Fixation holes spacing | 81mm / 109mm |
Speaker cable connection type | Screw or Banana plugs |
Acceptable diameter for banana plugs | 4mm |
Dimensions | 122 x 95 x 33mm |
Panel material | ABS Plastic |
Color | Black |
Screws not supplied | - |
Mounting type | To weld |
Connectic | Female |
Max panel thickness (mm) | N/A |
Accepts Banana Plugs | Yes |
Connector | Speaker terminal |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Gold |
Average votes 5.0 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Gilles D.
jean louis d.
Anders L.
Philippe D.
