Q acoustics 2050i Speakers Graphite Black (pair)
Q acoustics 3050 Speakers Graphite Black (pair)
By buying this product you get 138 loyalty points
Reference : 10182
699,00 €tax incl.
582,50 € tax excl.
Including 1,00 € for green tax
Shipping from France
Billing in France
Technical support in France
The 2050i's award-winning 2050i speaker is a flagship product in the 2000 line-up, and has nothing to envy the high-end column speakers in its class.
It is ideal for installation in large volumes (loft, large living rooms or listening room, etc ...) and adapts to home theater use as well as traditional listening.
Improved 165mm twin cone motors made of aramid / paper fiber produce surprising dynamics and generous frequencies, while the new two-in-one tweeter in the form of a dome with concentric rings surprisingly clear and soft frequencies at the top of the spectrum.
The enceinte 2050i is equipped with an integrated steel stabilizer skirt with grounding cleats.
Indeed, characterized by past distortion levels of reference of its category, it is suitable as well for the listening of music in hi-fi as for a scenario of home cinema.
This paire speaker is ideal for mounting on a stand or wall mount.
In short, small but sturdy, these speakers have surprising the most demanding:
Features:
  • Enclosure Type: 2-way SLR
  • Woofer: 2x 165mm
  • Heavy-duty motor: 25mm
  • Frequency response: 44Hz - 22kHz
  • Nominal impedance: 6 ohm
  • Minimum impedance: 4 ohm
  • Sensitivity: 92 dB
  • Recommended power: 25 - 150w
  • Transition Frequency: 2.6 kHz
  • Dimensions H / W / W in mm: 1006 x 321 x 270
  • Weight: 21kg per speaker
  • Sold by pair
  • 5 Year Warranty
The connections are located under the enclosure.
