Swans M200 MKII - Active Monitor Monitors
Swans M200 MKII - Enceintes Monitor actives
By buying this product you get 44 loyalty points
Reference : 5481
449,00 €tax incl.
374,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
The Swans M200 MKII high-performance active speakers are truly versatile.
Used as a proximity monitor in the recording studio, as a compact multimedia speaker or connected to an i-Pod, the possible applications of the Swans M200 MkII are endless.
The M200 MkII will astonish you with its extreme neutrality and the sound level that can be achieved in spite of its reduced dimensions.
The M200 is equipped with volume and tone controls (bass and treble) on the front panel.
the amintegrated entertainment with the use of components of very high quality and can quite measure up to an external hi-fi amplifier.
Given its price and performance, the M200 is unique in its class.
General Data
ModelHiVi M200MKII
System SeriesHi-end digital Multimedia system
Acoustic System
System Type2-way 4th order active vented box system
Drivers Configuration5 "mid-low driver, 25mm dome tweeter
Frequency Range56Hz-20KHz
Harmonic Distortion80Hz-20kHz≤1% (2.83V / 1m)
Sensitivity87dB (2.83V / 1m)
Nominal Impedance
Power Range10-60W
Amplifiers System
Rated Power35W ×2 RMS (5Ω, 1KHz, THD <0.1%)
Frequency Range20Hz-20kHz
Bass Adjust± 3dB (100Hz)
Treble Adjust± 3dB (10KHz)
Separation> 60dB
Signal-to-Noise> 80dB
distortionTHD <0.06% (8Ω, 1kHz, 10W)
Input sensitivity650mV
Input impedance22kΩ
Other Parameter
FinishedWalnut wood veneer / Black flat
Dimension (W × H × D (mm)) 192 × 230 × 350
Net WeightMain speaker: 7.8Kg
Subsidiary speaker: 6Kg
