By buying this product you get 48 loyalty points
Attention: The product is delivered configured in 110V. If your electrical network provides a voltage of 220V (Europe), it is imperative to configure the device in 220V using the switch on the back of the device before connecting it to the mains. An incorrect setting could damage your device.
The SPA500DSP subwoofer amplifier module from Dayton Audio offers many features in a compact and well-constructed format. It also offers a 97.9 dB signal-to-noise ratio, which makes it suitable for high-quality home audio use.
The amplifier subwoofer SPA500DSP by Dayton Audio has natively DSP functions. It offers a wide range of useful tools to centralize certain connections and meet certain settings on a single interface. We find in these functions:
This multiple support and computer equipment that accompanies to quickly assemble a complete and compact system while avoiding some of the most laborious efforts. The utility remains intuitive and simple as a whole. It is also a way to protect your equipment from accidental disruptions that could damage your speakers. Fewer physical buttons available for curious / children and more features (including the possibility to save your filter settings / EQ / limit order to find your preferred settings later.
This module is easily installed on a box or any similar surface.
The SPA500DSP is also equipped with secondary outputs in which one can connect the satellite speakers while taking advantage of filter EQ and capacity (or even the main speakers) and connecting the bulk of the installation on this Amp module.
The integrated equalizer allows you to easily get a report optimized for your room and your installation.
Combined with a micro speaker, this feature saves a lot of time and almost immediately have a sound system specifically configured for spatial constraints.
A special filter is dedicated to available outputs reserved for high-frequency speakers. In itself, it is even possible to use this amp module as a central element of a simple sound system with three elements for rendering affordable, very compact and especially centralized around a single element.
Height | 254 mm |
Width | 177.8 mm |
Depth | 50.8 mm |
Weight | 1.9 kg |
Alimentaton required | 120/220V |
Signal / N ratio | 97.9db (A-weighted) |
Output Power | 500 RMS |
Input | Jack 6.35mm |
Input | RCA |
Input | XLR |
Output | XLR |
Output | RCA |
Class | Class D / T |
Amplifier chip | N/A |
Power (W) | 500.0 |
