JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 0.47µF
Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every detail of the signal, while maintaining unparalleled naturalness and realism.
Reference : 10013
9,90 €tax incl.
8,25 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
Jantzen Audio Superior Z-Cap
Jantzen Audio Superior Z-Cap Condensateur
In particular, they are recommended for use as a capacitor for high-end tweeters or as a coupling capacitor in an amplifier. All Jantzen Audio Z-Cap capacitors have a nitrogen filling that allows the amount of foil per capacitor to be increased while eliminating the risk of evaporation that can be found in capacitors using oil or other dielectric fluids.
Superior Z-Cap capacitors are not polarized. The signal can therefore pass in both directions, without impacting the reproduction or sound performance.
Product typeCapacitor (Super MKP, non-polarized)
Capacity0.47µF
Voltage800VDC
Tolerance±2%
DielectricPolypropylene foil
ConstructionDual foil
Axial
ElectrodeAluminum metallized, vacuum deposited
Wires materialTinned OFC Copper
Dielectric absorption factor< 0.5% @ 20°C
Dielectric thicknessPB=6µm
Self-inductance0nH
Insulation resistance> 100000MΩ @ 20°C
Temperature range-55°C to +85°C
Metal layer thicknessPB=0.4µm
Metal layer conductivityPB=2.5Ω/cm²
DimensionsØ16 x 43mm
Poids13.4g
ColorRed
Tolerance (%)2.0
Capacitor capacitance0.047
Rated voltage (V)800.0
Capacitor typeFilm capacitor
Capacitor formatAxial
2 reviews
Excellent !
Les condensateurs Jantzen de la série Z-Cap Superior sont vraiment excellents, aussi bien pour le filtrage des haut-parleurs que pour améliorer les circuits électroniques hifi de tout type.
La musicalité progresse nettement, n'hésitez pas à les utiliser.
Livraison rapide, bravo Audiophonics.
This review has been posted for JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 0.47µF
Excellents, vraiment !
Toujours aussi excellents ces condensateurs, que ce soit pour du filtrage HP ou pour remplacer des condensateurs dans des éléments électroniques haute-fidélité.
Celui-ci remplace un condo MKP chinois 0.47 µF dans mon préampli phono MM à tubes (1 tube ECL82 + 1 tube 6z5p + 2 tubes 12au7 + 2 tubes 12ax7) clone d'un Audio Note et le résultat est là.
Livraison express, félicitations à Audiophonics.
Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system...
