JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 2.2μF
Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every detail of the signal, while maintaining unparalleled naturalness and realism.
Reference : 6592
15,90 €tax incl.
13,25 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
Jantzen Audio Superior Z-Cap
Capacitor 800V 2.2µF
Jantzen Audio Superior Z-Cap Condensateur
In particular, they are recommended for use as a capacitor for high-end tweeters or as a coupling capacitor in an amplifier. All Jantzen Audio Z-Cap capacitors have a nitrogen filling that allows the amount of foil per capacitor to be increased while eliminating the risk of evaporation that can be found in capacitors using oil or other dielectric fluids.
Superior Z-Cap capacitors are not polarized. The signal can therefore pass in both directions, without impacting the reproduction or sound performance.
Product typeCapacitor (Super MKP, non-polarized)
Capacity2.2µF
Voltage800VDC
Tolerance±2%
DielectricPolypropylene foil
ConstructionDual foil
Axial
ElectrodeAluminum metallized, vacuum deposited
Wires materialTinned OFC Copper
Dielectric absorption factor< 0.5% @ 20°C
Dielectric thicknessPB=6µm
Self-inductance0nH
Insulation resistance> 100000MΩ @ 20°C
Temperature range-55°C to +85°C
Metal layer thicknessPB=0.4µm
Metal layer conductivityPB=2.5Ω/cm²
DimensionsØ25 x 45mm
Poids29g
Tolerance (%)2.0
Capacitor capacitance2.2
Rated voltage (V)800.0
Capacitor typeFilm capacitor
Capacitor formatAxial
4 reviews
Comme des Mundorf Suprême Classics.
Aussi performants que les Mundorf Suprême classiques c'est dire !!
J'adore déjà les condensateurs Jantzen Cross-Cap et là on est largement au-dessus en terme de musicalité.
Parfaits pour le montage de mes filtres Cabasse Caravelle M2 trouvés sur le forum Cabasse (9 condensateurs et 7 selfs et une résistance) 2 condensateurs en parallèle pour obtenir les 4,4 µF requis et montés en série derrière le Cabasse Dom12.
Voilà un Dom12 calmé et devenu très performant, plus aucune mise en avant du médium, mariage impeccable avec le tweeter Dom4 lui-aussi filtré comme il se doit avec ces condensateurs Jantzen Supérior Z-Cap.
Audiophonics propose des articles de grande qualité avec une livraison express.
This review has been posted for JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 2.2μF
fantastic
sound quality, scene creation, softness,detail, i loved the all. i liked it more than dayton mpts
Timbre natural, realismo sonoro.
Usados como desacoplo en la entrada del ampli, en un equipo que ya sonaba muy bien. Esperaba cierta mejora con respecto a los Cross Cap que había pero el resultado superó lo esperado. La mejora es general, el ataque de las notas y el timbre de las voces e instrumentos es súper natural, hay mucha más información y detalle, llegando a engañar al cerebro que cree que tiene los músicos delante... Yo mismo soy músico, tengo muy claro cómo suenan las cosas en la realidad. De verdad que no esperaba semejante mejora. Un 10/10 a los condensadores. Por parte de Audiophonics todo perfecto, envío rápido y precios razonables pero eso ya lo sabíamos...
Condensateurs JANTZEN Superior et Alumen
Livrés rapidement et bien emballés
Je complèterai mon avis après écoute de mes enceintes avec ces composants dans le filtre passif
Hervé
Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system...
