SUPRAVOX 135 LB - 13 cm - 95 dB - 80 Hz / 18 kHz
Supravox 135 LB - 13 cm - 95 dB - 80 Hz / 18 kHz
Reference : 30
149,00 €tax incl.
124,17 € tax excl.
The 135 LB is a real broadband running without bicone.
The response curve of this membrane extends from up to 18kHz from the control of the membrane treatment of the Supravox laboratory.
The optimization of the membrane / coil couple has made it possible to gain even more speed in membrane and in sensitivity whilst pushing the transducer high cut to the limit of the audible.
These parameters make it a loud speaker bafflable in volumes even more reduced than its previous.
In the Supravox column dedicated to 13 cm its response is stable at +/- 3 dB from 60Hz to 18 kHz.
The 13 cm has privilege for the lovers of a medium clear and precise.
Sensitivity 1 W / 1m to Fs95 dBDrill hole diameter  122 mm
Bandwidth80to 18kHzHP Depth80 mm
Impedance8 ohmsfs  80 Hz
Power consumption RMS  35Wqt0.3
Weight1.7 kgQe0.3
Suspension5-ply paperQm3.6
Linear Excursion  6 mmGos14 L
Ferrite Diameter  96 mmbl5.4
Magnetic field1.4 TRe5.2
HP Diameter134/151 mmcms1
Bowl Thickness  Sheet metal 5mmmms3.3g
Mounting hole diameter140 mmsd86.5 cm²
Colissimo - TNT - SoColissimo
Sans doute un des plus beau Medium au monde dans sa gamme de prix.
Nécessite toutefois un tweeter étant légèrement trop court en haut et une charge TQ et/ou un caisson dans le bas.
This review has been posted for SUPRAVOX 135 LB - 13 cm - 95 dB - 80 Hz / 18 kHz
