SUPRAVOX 165 LB - 16 cm - 95 dB - 50 Hz / 19 kHz
Supravox 165 LB - 16 cm - 95 dB - 50 Hz / 19 kHz
By buying this product you get 20 loyalty points
Reference : 31
209,00 €tax incl.
174,17 € tax excl.
This loudspeaker, created in 2001, can be baffled in rather small volumes, in bass reflex or TQWT it can do without subwoofer for a fast reproduction and powerful low frequencies up to 50 Hz.
This is the ideal speaker for creating a pair of library loudspeaker.
Plans are available on the Supravox site HERE . It can also be used in wide-band midrange in quality 3-way speakers.
Sensitivity 1 W / 1m to Fs  95 dBDrill hole diameter  160 mm
Bande passerine60 to 19 kHzHP Depth85 mm
imimpedence8 ohmsfs64 Hz
Puimax. RMS  35 WRe4 ohms
Poids1.9 kgqt  0.42
SUSPENSION5-ply paperQe0.46
Excursion linear  6 mmQm4.8
Havemantle ferrite  96 mmVas33 L
chmagnetic amp1.4 Tbl4.7
diameter HP  185 mmcms0.7
Epsalad bowl  Alu 10mmmms5.5 g
distance mounting holes175 mmsd165 cm²
Colissimo - TNT - SoColissimo
