SUPRAVOX 215 RTF64 - 21 cm - 97 dB - 50 Hz / 10 kHz
Supravox 215 RTF64 - 21 cm - 97 dB - 50 Hz / 10 kHz
By buying this product you get 20 loyalty points
33
209,00 €tax incl.
174,17 € tax excl.
This broadband and high-performance speaker is none other than the legendary HP 95 evolution that equip the studios of the house of radio, ORTF, RAI, RTL and EUROPE 1. Opera certified, it provides a warm, clear and precise listening experience and offers a wide range of editing possibilities.
Ideal listening with a low-power amp (tube or transistor) of about 10W.
In the plane panel, the spatial presence of the sound will enchant you, the HP expresses at best its great dynamics.
In TQWT it will bring out all the finesse of your favorite listening.
This HP can be reinforced by a JBL 2405 or B & C D-32 tweeter with a single cut to 10kHz by a capability of 0.47 or 0.33 uF.
The bass can be reinforced, especially in the flat panel by the 285 or 400 SUPRAVOX cut at 100Hz.
Sensitivity 1 W / 1m to Fs97 dBDrill hole diameter212 mm
Bandwidth50 to 10kHzHP Total Depth100 mm
Impedance8 ohmsfs60 Hz
Max. RMS 35 WRe6.5 ohms
Weight2.8 kgqt0.58
Suspension3-ply paperQe0.6
Linear Excursion4 mmQm7
Ferrite magnet120 mmVas80 L
Magnetic field1.5 Tbl5.8
HP Diameter224 / 237mmcms0.8
Epsalad bowlAlu 10mmmms8.5 g
Distance fixing holes227 mmsd
263 cm²
Colissimo - TNT - SoColissimo
