SUPRAVOX 215 S - 21 cm - 94 dB - 45 Hz / 10 kHz
Supravox 215 S - 21 cm - 94 dB - 45 Hz / 10 kHz
By buying this product you get 30 loyalty points
Reference : 35
309,00 €tax incl.
257,50 € tax excl.
The 215 Signature is an evolution of the 215 RTF. It is the culmination of the Supravox experiment on membrane treatments and optimization of the motor / coil torque.
The motor and the coil have been modified to provide this loudspeaker with a greater diaphragm travel or better bass reproduction without dynamic compression.
The linear excursion increases from +/- 2mm (RTF versions) to +/- 4mm. It offers a deep deeper tense and precise.
All this is paid for by a sensitivity of 94dB / W.
This 215 is to favor for the followers of a very balanced listening. Without the bicone the response is linear up to 10 kHz.
Sensitivity 1 W / 1m to Fs94dBDrill hole diameter212 mm
Bandwidth45 to 10kHzHP Depth105 mm
Impedance8 ohmsfs50Hz
Power consumption RMS35 WRe6.5 ohms
Weight3.3 kgqt0.8
Suspension3-ply paperQe0.9
Linear Excursion8 mmQm8
Ferrite Diameter120 mmVas85L
Magnetic field 1.2 T bl5
HP Diameter224 / 237mmcms0.8
Bowl ThicknessAlu 10mmmms<sVerdana, Arial, Helvetica, sans-serif; font-size: small; "> 8 g
Distance fixing holes227 mmsd
263 cm²
Colissimo - TNT - SoColissimo
