SUPRAVOX 215 S BIC Bi-Cone Speaker Driver Full Range 35W 8 Ohm 93dB 45Hz - 19kHz Ø 21cm
Supravox 215 S Bic - 21 cm 93 dB - 45 Hz 19 kHz
By buying this product you get 40 loyalty points
Reference : 36
409,00 €tax incl.
340,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
The 215 Signature is an evolution of the 215 RTF Bicone. It is the culmination of the Supravox experiment on membrane treatments and optimization of the motor / coil torque.
A new membrane treatment provides an even more harmonious and gentle overlap between the membrane and the bicone as well as better control of membrane fractionation.
The motor and coil have been modified to provide this speaker with greater diaphragm travel, better bass reproduction without dynamic compression.
The linear excursion changes from +/- 2mm to +/- 4mm. It offers a deep deeper tense and precise.
All this is paid for by a sensitivity of 93 dB / W.
This 215 is to be preferred for the followers of a very balanced listening.
Sensitivity 1 W / 1m to Fs93 dBDrill hole diameter212mm
Bandwidth45 to 19 kHzHP Depth105 mm
Impedance8 ohmsfs50 Hz
Max. RMS 35 WRe5.5 ohms
Weight3.3 kgqt0.8
Suspension3-ply paperQe0.9
Linear Excursion8 mmQm8
Ferrite Diameter120 mmVas85 L
Magnetic field1.2 Tbl4.4
HP Diameter224 / 237mmcms
0.8
Bowl Thickness Alu 10mm mms10 g
Distance fixing holes227 mmsd
263 cm²
Speaker Power (W RMS)35.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)210.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)93.0
Max Linear Excursion (Xmax) (mm)8.0
Lowest frequency (Hz)45
Highest frequency (Hz)19000
