SUPRAVOX 285 GMF - 28 cm - 99 dB - 40 Hz / 7 kHz
Supravox 285 GMF - 28 cm - 99 dB - 40 Hz / 7 kHz
By buying this product you get 26 loyalty points
269,00 €tax incl.
224,17 € tax excl.
285 GMF
This high-bandwidth, high-output loudspeaker offers you a very fast and pleasant listening.
Ideal listening with a low power amp (tube or transistor) of about 10W, it also supports higher powers for use in subwoofers.
In a flat panel, it will reinforce the 215 RTF with the same degree of reproduction precision, to add a bass reinforcement and ensure a comfortable and balanced listening.
In column TQWT it will bring out all the finesse of your favorite listening. In case RJ, bass reflex or symmetrical, it will be a grave of accompaniment of the most precise.
This HP can be coupled with a 1-inch engine mounted on our horn. Cut to 500Hz the response curve will be straight to ± 2 dB from 35 to 20 000Hz.
Sensitivity 1 W / 1m to Fs99 dBa, Arial, Helvetica, sans-serif; font-size: small; "> Fs47Hz
Bandwidth40 to 7kHzRe6.5 ohms
Impedance8 ohmsqt0.38
Power consumption RMS70 WQe0.39
Weight3.5 kgQm8
Suspension3-ply paperVas150 L
Linear Excursion8 mmbl10.7
Ferrite magnet120 mmCms
Magnetic field1.4 Tmms20 g
HP Diameter290 / 307mmsd
471 cm²
Thickness of bowl Aluminum 8mm
HP Depth120 mm
Distance fixing holes290 mm
Drill hole diameter 270 mm
Colissimo - TNT - SoColissimo
