SUPRAVOX 400 GMF Speaker Driver Woofer 120W 8 Ohm 96dB 24Hz - 4000Hz Ø 35cm
Supravox 400 GMF - 35 cm - 96 dB - 24 Hz / 4 kHz
By buying this product you get 74 loyalty points
Reference : 7528
749,00 €tax incl.
624,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
This high-performance (96 dB) bass speaker uses the same mobile equipment as the 400-2000.
Its difference lies in the engine, since it uses a 220 mm ferrite in place of the Alnico.
These qualities allow it to be directly coupled with a 1-inch engine mounted on our roof.
Mounted in a bassreflex or jensen box, cut at 500Hz, the response curve will be straight to ± 2 dB up to the final frequency of the 1-inch motor.
Il is also ideal for subwoofer use (symmetrical load).
Specifications:
Sensitivity 1 W / 1m to Fs 96 dBfs26 Hz
impedance 8 ohmsRe6.5 ohms
Bandwidth24 to 4kHz qt0.32
Power consumption RMS120 WQe0.33
Weight10.7 kgQm10
SuspensionCanvasVas489
Linear Excursion 10 mmbl15.8
Ferrite Magnet220 mmcms
0.47
Magnetic field 1.8 Tmms70 g
HP Diameter 404 mmsd
855 cm²
Bowl ThicknessAlu 10mm
Distance fixing holes382 mm
Diameter of drilling enclosure 358 mm
HP Depth165 mm
Near Field Frequency Response:
https://www.audiophonics.fr/images2/7528/7528_400gmf_4.jpg
Frequency response from 200 Hz to 20 kHz in the axis:
https://www.audiophonics.fr/images2/7528/7528_400gmf_1.jpg
Frequency response from 200 Hz to 20 kHz at 30 °:
https://www.audiophonics.fr/images2/7528/7528_400gmf_2.jpg
Impulse response:
https://www.audiophonics.fr/images2/7528/7528_400gmf_5.jpg
Waterfall
https://www.audiophonics.fr/images2/7528/7528_400gmf_6.jpg
Impedance:
https://www.audiophonics.fr/images2/7528/7528_400gmf_7.jpg
=> More information on the Supravox website
Speaker Power (W RMS)120.0
Speaker TypeWoofer
Impedance (Ω)8
Loudspeaker diameter (mm)350.0
Diaphragm typeN/A
Efficiency / Sensitivity (dB)96.0
Max Linear Excursion (Xmax) (mm)10.0
Lowest frequency (Hz)24
Highest frequency (Hz)4000
