SUPRAVOX 215 EXC - 21 cm - 90 to 99 dB - 50/20 kHz
Supravox 215 EXC - 21 cm - 90 à 99 dB - 50 / 20 kHz
By buying this product you get 125 loyalty points
Reference : 43
1 259,00 €tax incl.
1 049,17 € tax excl.
A mobile crew and a response identical to the 215-2000 alnico.
Its advantage is the possibility of adjusting these parameters thanks to a powerful electromagnetic motor. Adaptable to many speakers, it requires an external power supply (ideal from 10 to 14V for 5A).
Sensitivity 1 W / 1m to Fs90 to 99 dBFood0 to 12 Volts DC.
Bandwidthfamily: Verdana, Arial, Helvetica, sans-serif; font-size: small; "> 50 to 20 kHzMagnetic field0 to 2 T
Impedance4 ohmsHP Diameter227/237 mm
Power consumption RMS20 Wbowl ThicknessAlu 10mm
Weight7.1 kgDistance fixing holes227 mm
SuspensionpaperDrill hole diameter212 mm
Resonance Frequency50 HzHP Depth147mm
Linear Excursion+/- 5 mmsd
283 cm²
<spanVerdana, Arial, Helvetica, sans-serif; font-size: small; "> Fs
mms
cms
Re DC
49 Hz
7 g
1
4
Food
8 V
9 V
10 V
11 V
12 V
13 V
Vas97.896.598.299.410297.8
qt
0344
0309
0286
0268
0.26
0.25
Qe
0357
0.32
0295
0277
0269
0256
Qm
9506
9227
9174
8303
8036
9419
bl
5.84
6.23
6.43
6.63
6.65
6.9
SPL ref
98>
98.3
98.7
99
99.4
99.9
Colissimo - TNT - SoColissimo
