SUPRAVOX 215-2000 - 21 cm - 99 dB - 50 Hz / 20 kHz
Supravox 215-2000 - 21 cm - 99 dB - 50 Hz / 20 kHz
By buying this product you get 125 loyalty points
Reference : 39
1 259,00 €tax incl.
1 049,17 € tax excl.
This high-bandwidth, high-performance loudspeaker combines extreme technological options and reports on research conducted by the new SUPRAVOX team.
Everything has been implemented to obtain this exceptional loudspeaker: hyperbolic paper without bicone, suspension with displacement max. of 2cm, engine block in Alnico (3.5Kg) and core of pure iron to obtain 21000 Gauss of magnetic field.
The 215-2000 is the result of modern technological possibilities and the quest for audiophiles. It is astonishing by its precision and clarity in the medium, by the aggressive presence of the treble, by the speed and the sharpness of its bass, all with exceptional dynamics.
In flat panel it should be reinforced by a 285 or a 400 to complete the extreme low. In 1-channel, TQWT column or rear-horn design, it justifies its position as the ultimate broadband loudspeaker.
18% "> Fs
Sensitivity 1 W / 1m to Fs99 dB
47Hz
Bandwidth50 to 20kHzRe4 ohms
Impedance4 ohmsqt 0.23
Power consumption RMS20 WQe0.24
Weight7.1 kgQm8
Suspension5-ply paperVas121 L
Linear Excursion10 mmbl6.5
Alnico Magnet3.5 kg Cms
1
Magnetic field2.1 Tmms
7g
HP Diameter224 / 237mmsd
283 cm²
Colissimo - TNT - SoColissimo
