SUPRAVOX TG1 Golden titanium dome
Supravox TG1 Dôme titane doré
By buying this product you get 32 loyalty points
Reference : 65
329,00 €tax incl.
274,17 € tax excl.
This tweeter is equipped with a dome of 25 mm titanium covered with gold, in order to obtain a dome as rigid and light possible. Thanks to a specific dome treatment, we have retained all the qualities provided by titanium (impulse response, linearity, efficiency) and eliminate any metallic aggressiveness at the top of the spectrum.
It is equipped with a powerful neodymium engine which allows it to reach 98 dB of efficiency.
This tweeter will surprise you by its natural reproduction, its softness, its precision and its high efficiency.
The TG1 is available in 4 ohm (TG1 / 4) or 8 ohm (TG1 / 8) versions.
Bandwidth2500 to 20 kHz +/- 1.5 dB
Sensitivity98 dB / W at 1m
Impedance4 and 8 ohms
DC resistance (TG1 / 4)3.9 ohms
DC resistance (TG1 / 8)6.1 ohms
Power consumption RMS50 W
Resonance Frequency1200 Hz
Diameter110 mm
Mounting diameter100 mm
Front panel thickness5 mm
Depth40 mm
Weight0.5 kg
Colissimo - TNT - SoColissimo
