STUFFSON 5K Audio Adhesive Polymer Damping 500x600mm 0.3m²
Stuffson 5Kg Audio Adhesive Damping 500 * 600 mm
Qualitative alternative to traditional bitumen sheets
Reference : 10698
7,90 €tax incl.
6,58 € tax excl.
Shipping from France
Billing in France
Technical support in France
The Stuffson range is made of anti-vibration polymer shock absorbers which increase the density of acoustic walls (enclosures, thin walls, chassis Hifi devices, computers).
The primary advantage of the polymer is the maneuverability of the product which does not break unlike the bitumen-based materials. Cutting is also easier.
The Stuffson is in sheets with a thickness of between 1.75 and 5 mm depending on the desired density (3.5, 5, 7 and 10 kg / m2). Stuffson can be cut to the desired size and has an adhesive underlay or covered with a polypropylene protective film that is found on the surface of the product.
Properties:
  • Stuffson allows the addition of mass increasing the insulation of a wall to sound waves (theoretical mass law).
  • The theoretical gain is 6 db of acoustic insulation by doubling the mass of the support
  • The damping of the vibrations via dissipation of the mechanical energy in the form of heat by internal friction between the molecules constituting the material.
  • The intrinsic properties of the material: the elastic characteristics of the product increase the sound attenuation index at the critical frequency of the material to which it is applied.
  • Due to its inertia and its industrial design, Stuffson is ideal for the internal treatment of loudspeaker walls, car doors, facades for home cinema.
Applications:
The applications are wide:
  • Reduces the impact of noise on the ground, on any metal surface, sheets, floors, thin walls.
  • Reinforcement of all thin and vibrating walls by mass supply: bathtubs, sinks, metal drawers, Hifi speakers, computers.
Characteristics:
  • Tensile strength: 30N / cm2.
  • Elongation resistance: 300%.
  • Resistance to compression: 4.84Kg / cm2.
  • Cold folding: -20 ° C.
  • Thickness: 2.5mm.
  • Weight per unit area: 5KG / m2.
  • Format of a sheet: 60 * 50 cm.
  • Weight per sheet 5kg per m2.
DB on wall with and without Stuffson.
4 reviews
STUFFSON 5K Amortissement Polymère Adhésif 500x600mm 0.3m²
Très bon produit et surtout livraison au Japon en 5/6 jours dans la "Lozère japonaise" !
STUFFSON 5K Amortissement Polymère Adhésif 500x600mm 0.3m² a été posé sur le plancher d'une Mazda 5 afin de réduire les bruits de roulement. Bonne efficacité !
A recommander à ceux et celles qui veut rouler en voiture dans plus de silence.
Merci AUDIOPHONICS
This review has been posted for STUFFSON 5K Audio Adhesive Polymer Damping 500x600mm 0.3m²
efficace et pas cher
Pour une somme dérisoire vous pouvez améliorer votre écoute au meme titre qu'une bonne prise secteur ou un cable hifi secteur ou de modulation. J'ai fait plusieurs essais sous des pieds vibrapods , sur mon ampli , sous une étagére en verre de mon meuble hifi , N'hésitez pas à l'éssayer pour tout type d'applications hifi , quitte parfois à le le retirer en fonction du résultat et le laisser pour d'autre. A essayer sans apriori. Recommandable.
Amortissement
excellent pour amortir les lecteurs CD et supprimer les parasites sur la tête de lecture
super
j' en mets dans toutes mes électroniques, cd,ampli, sur toutes partie tolée, gain en propreté et assise sur un bon découplage !!
