I received my ordered items so fast even christmas season. So I can enjoy my time with the parts for amplifier. I thank you, Audiophonics!
Tetrode Amplification Tubes (Matched Quad)
The Electro Harmonix 6CA7 amplifier tubes are classic tetrodes in Big Bottle format. They are designed to adapt to amplifiers with high gain while providing precision and sound richness to restore the integrity of the original audio signal. Their design allows them to saturate less quickly than many other tubes, thus preserving beautiful sound clarity, even at high volume. 6CA7 tubes are also compatible with EL34 models, for example for replacement.
These Electro Harmonix 6CA7 tubes are delivered by 4 and are matched by the brand. This process allows to obtain almost identical values for each tube in order to improve its performance. Ideal for perfect assembly.
Product type | Tubes |
Matched | Yes, quad |
Heater voltage | Min. 5.7V Max. 7V |
Heater current (@ heater voltage = 6.3V) | 1.5A +/-0.1 |
Max cathode current | 150mA |
Cathode / Heater voltage | +/-300V |
Max plate voltage | 800V |
Plate current | 100mA +/-20 * |
Max plate dissipation | 25W |
Max grid 1 negative voltage | 100V |
Max grid 1 circuit resistnace | Fixed bias : 0.5MΩ Automatic bias: 0.7Ω |
Max grid 2 voltage | 425V |
Grid 2 current | <= 20mA * |
Max grid 2 dissipation | 8W |
Transconductance | 10mA/V * |
Output power | >= 9W ** |
Non linear harmonic distorsion coefficient | <= 13.5% ** |
Dimensions | 110mm x Ø38mm |
* Uh = 6.3V; Up = 250V; Ug2 = 250V; Ug1 = -13.5V
* Uh = 6.3V; Up = 250V; Ug2 = 250V; Ug1 = -13.5V; Ug1 alt.eff = 9.6V; R load = 2kΩ
Average votes 4.7 / 5 6 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
YOSHIBUMI O.
Bylna D.
Philippe L.
Jean-Pierre f.
Christophe v.
