Soldered to Viborg pure silver XLR connectors and it is a stunning interlink with lots of detail and a very nice soundstage with depth.
Not sharp at all
Shielded UP-OCC Silver Interconnect Cable Ø10mm
The NEMOI series from the manufacturer Neotech is the result of extensive research in the field of audio cable. The Neotech NEMOI-1220 modulation cable, combining PTFE insulation and UP-OCC Silver conductors with rectangular cross-section, has a special architecture that significantly reduces the inductance and capacitance effect.
If you are looking for a very high quality modulation cable with a flawless design, the Neotech NEMOI-1220 is for you. The result is surprising, combining with listening often contradictory qualities such as sitting in the bass and a readable, natural sound scene with high definition in the medium, without auditory fatigue.
Specifications | ||
Product type | Interconnect cable | |
Matériau conducteurs | Cross-Section UP-OCC Silver | |
Number of conductors | 2 | |
Conductors section | 0.33mm² | |
Shielding | Copper-Mylar Foil + Braided Copper | |
Insulation | PTFE + PE + PVC + Cotton | |
External sheath | PE + PVC | |
Resistance | 0.054 Ohm/m | |
Capacity | 38.19pF/m | |
Inductance | 0.86µH/m | |
External diameter | 10mm | |
Color | Blue | |
Quantity | Sold per meter |
Diameter (mm) | 10.0 |
Length (m) | Sold by length |
Insulation material | PTFE |
Insulation material | PVC |
Insulation material | PE |
Shielding | Yes |
Section (mm²) | 0.33 |
Conductors material (Cable) | Silver |
Conductors Plating (Cable) | None |
Ground / Shielding | Yes |
Average votes 5.0 / 5 11 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Harry H.
François M.
Guerino F.
Marcos Pérez J.
Fabian b.
