ifi Audio Gemini Cable USB-A Male double / USB-B Male OFHC Copper 1.5m
ifi Audio Mercury USB-A Male / USB-B Male Cable Copper OFHC 1m
By buying this product you get 27 loyalty points
9254
279,00 €tax incl.
232,50 € tax excl.
This high-quality USB cable is particularly attractive due to its dual USB 2.0 output dedicated to powering and transferring audio data.
Indeed, to separate these two elements is a guarantee of quality allowing you to get rid of the residual noises linked to the feed that disturb the signal.
It has the particularity of being extremely faithful to the impedance recommended by the USB standard (+/- 1%) which has the advantage to bring a better transmission of the signal.
On the other hand, the cable is equipped with 3 filters acting against RFI interference.
99.9% deoxygenated OFHC copper conductor .
Compatible with standard 1.1 & 2.0 with transfer rates up to 480Mb / s .
Works with any USB 2.0 device on a PC or MAC platform.
Characteristics :
  • Metal Head Connectors: Gold Plated
  • Male to Male to Male-B Male to Male Cable (24bit / 192kHz)
  • Double shielding: aluminum strip plus copper braid
  • Copper conductor OFHC 99.9% pure (deoxygenated)
  • Insulation: Polyethylene
  • Impedance: 90 Ohm (low variation 1%)
  • filtering:3 filters (anti RFI)
  • Cable Length: 1.5m
  • Weight: 400g
ifi Gemini
ifi Gemini
ifi
ifi Gemini
Length max.- of 1m
PlatingGold-plated
ConnecticMale
Channel2 channels (Stéréo)
Download
[FR] Gemini - User Manual
User manual for the Ifi Audio Gemini USB cable in French.
Download (456.62k)
Colissimo - TNT - SoColissimo
2 reviews
Complément
En complément de mon commentaire précédent :
- Mon DAC est un NAIM DAC sans connexion USB B et non un V1.
- J'ai aussi effectué des comparaisons avec un cable de meilleure qualité (Acqvox USB environ 175 euros en 1m) : la différence est encore sensible mais moindre qu'avec le Pangea.
J'en déduis que la séparation de l'alimentation et du data a une influence mais que la qualité de transmission des données influe aussi.
This review has been posted for ifi Audio Gemini Cable USB-A Male double / USB-B Male OFHC Copper 1.5m
Exceptionnel
Utilisé pour connecter un MB Pro à une interface USB MF 192 elle même raccordée à un NAIM DAC v1 à l'aide d'un Oyaide DB510 BNC. Le logiciel de lecture est Amarra les fichiers FLAC de 44 à 192.
Je l'ai comparé d'une part à un cable USB PANGEA de bonne qualité et à un liaison directe optique en fibre de verre SILFLEX GLASS DIGITAL.
1. Liaison directe optique : bien que le cable utilisé soit le top, cette liaison n'est pas à la hauteur : les deux extrémités du spectre sonore sont écourtées, l'ensemble manque de détail et de relief.
2. Cable PANGEA et interface MF 192 : on retrouve de la matière et une scène sonore impressionnante : bon rapport qualité prix.
3. GEMINI Y - tout est mieux : plus de matière, plus de relief, des basses plus profondes et rondes à la fois, des détails d'instruments qui apparaissent : on monte le volume sans la moindre retenue.
4. GEMINY Y + Audiophonics Alimentation Linéaire régulée 5V : une amélioration ténue sur le son (sur le bas du spectre ?) - En revanche une amélioration de l'ergonomie puisqu'une seule fiche USB à brancher sur le MAC MB Pro qui n'en possède que 2 et un interrupteur en face avant qui allume/éteint le MF 192.
Note utile, les 3 blocs de guidage sont mobiles : les deux prises USB n'ont pas forcément besoin d'être voisines.
Conclusion : une fois en place impossible de revenir en arrière - vivement recommandé même si le cable est plus cher que l'interface.
