OEAUDIO OEOTG USB-C to Micro USB OTG USB Cable 12cm
OEAUDIO OEOTG Micro USB to USB-C OTG USB Cable
The OEOTG from OEAudio is a USB OTG cable of excellent quality, benefiting from a careful design, using components to ensure very good performance.
Reference : 14939
24,90 €tax incl.
20,75 € tax excl.
Last items in stock !
Shipping date: 19-04-2024.
Shipping from France
Billing in France
Technical support in France
OEAudio OEOTG
OEAudio OEOTG Câble USB OTG Micro USB vers USB-C
It integrates insulated OFC copper conductors with a cross section of 0.081mm² (28AWG) for data transmission and a conductor, also made of OFC copper but with a cross section of 0.129mm² (26AWG) for power supply. Each conductor is independently insulated with a PVC sheath. In the center is a 0.4mm diameter OFC copper drain wire. The assembly is shielded with aluminum foil to eliminate interference. A PVC sheath covers the end of this cable. Solderings are made with silver tin to maintain an excellent conductivity.
This cable is fully compliant with USB 2.0 Hi-Speed specifications and therefore has an impedance of 90 Ohm. It also supports a voltage of 5V and a current of 200mA.
This model is equipped on the one hand with a USB-C connector and on the other hand with a Micro USB connector.
This cable works only in the USB-C to Micro USB direction.
Product typeOTG USB Cable
Connectors1x Male USB-C
1x Male Micro USB
Length12cm
ConductorsOFC Copper
Conductors sectionDATA : 0.081mm² (28AWG)
POWER : 0.129mm² (26AWG)
ShieldingAluminum foil
External sheathPVC
Impedance90Ω
Voltage / Current5V 200mA
Length (m)0.12
ShieldingYes
Section (mm²)0.0810
ConnectorUSB-C
ConnectorMicro USB
