OEAUDIO OEOTG USB-C to USB-C OTG USB Cable 12cm
The OEOTG from OEAudio is a USB OTG cable of excellent quality, benefiting from a careful design, using components to ensure very good performance.
Reference : 14938
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
OEAudio OEOTG
OEAudio OEOTG Câble USB OTG USB-C vers USB-C
It integrates insulated OFC copper conductors with a cross section of 0.081mm² (28AWG) for data transmission and a conductor, also made of OFC copper but with a cross section of 0.129mm² (26AWG) for power supply. Each conductor is independently insulated with a PVC sheath. In the center is a 0.4mm diameter OFC copper drain wire. The assembly is shielded with aluminum foil to eliminate interference. A PVC sheath covers the end of this cable. Solderings are made with silver tin to maintain an excellent conductivity.
This cable is fully compliant with USB 2.0 Hi-Speed specifications and therefore has an impedance of 90 Ohm. It also supports a voltage of 5V and a current of 200mA.
This model is equipped with a USB-C connector at each end.
OEAUDIO OEOTG Câble USB OTG USB-C vers USB-C
Product typeOTG USB Cable
Connectors2x Male USB-C
Length12cm
ConductorsOFC Copper
Conductors sectionDATA : 0.081mm² (28AWG)
POWER : 0.129mm² (26AWG)
ShieldingAluminum foil
External sheathPVC
Impedance90Ω
Voltage / Current5V 200mA
Length (m)0.12
ShieldingYes
Section (mm²)0.129
Section (mm²)0.0810
ConnectorMicro USB
ConnectorUSB-C
