ELECAUDIO CH-22G Sector plug Switzerland SEV 1011 Silver + Gold Ø17mm
ELECAUDIO CH-22G Prise Secteur Suisse SEV 1011 Argent+Or Ø17mm
Reference : 5597
19,90 €tax incl.
16,58 € tax excl.
Available
Shipping date: 21-06-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
ELECAUDIO CH-22G Switches Sector Switzerland SEV 1011
The reference Schuko plug CH-22Gdistinguishes itself at first glance by itsblack anthracite nylon bodywith impeccable finishing and ideal proportions.
Featuring a silk-screened silvery screen with the color of the brand, this chassis allows to receive the most sophisticated cables whose diameter often proves incompatible with the conventional outlets.
With herInsertion ring to limit diameter to 17mm , with a greenhouse flexible rubber cableintegration, the CH-22G receives without difficulty cables of large diameter of theref = "https://www.audiophonics.fr/elecaudio-cs331b-cable-secteur-triple-blindage-3x350mm2-p-4715.html">CS-331B, the triple shielded mains cable of the same manufacturer.
Summum of refinement, all metal parts, including contact poles and earthing, were double plating Silver + Gold
This technique ensures that the connectorsperfectly smooth and uniform coating , completely free of the imperfections inherent in a single layer plating.
Visually, the difference is blatant, and this extra zeal in the use of precious metals also benefits the longevity of the CH-22Gimmunized against any form of'oxidation
The internal connection terminals also deserve attention: They are equipped with large fastening screws and therefore do not require any welding, they are capable of receiving very large conductors ( up to 12mm² section! )
Since the screw is in direct contact with the cable, it is advisable to use copper tips to protect from shear.
Finally, we will appreciate the small diagram directly engraved within the catch, and provides information on the optimum length of cable to be stripped . Since you are told that nothing has been left to chance ...
Specifications:
  • TakenSEV 10113 Screw Connectors
  • Double Plating:Silver + Gold 0.2μ
  • Contact Plating: Brass Alloy58% copper
  • Maximum Driver Section:12mm²(4mm of Diameter)
  • Maximum Cable Diameter: 17mm
  • Voltage / Voltage Rating: 16A / 250V
  • Overall Length: 90mm
  • Diameter: 38mm
  • Weight: 120g
https://www.audiophonics.fr/images2/5597/5597_ELECAUDIO_CH22G_2.jpg
https://www.audiophonics.fr/images2/5597/5597_ELECAUDIO_CH22G_1.jpg
https://www.audiophonics.fr/images2/4732_ELECAUDIO_PS-22G_6.jpg
https://www.audiophonics.fr/images2/SCHEMA_PHASE.jpg
Cable schematics
MaterialLaiton
PlatingGold-plated
For cable diameters17
ConnectionScrew
ConnecticMale
FormatType J
Colissimo - TNT - SoColissimo
Rien à dire
Ou plutôt si.
Comme d'habitude avec cette marque je ne suis jamais déçu.
De la qualité visuelle aux finitions interne tout est bien pensé.
Bien vu aussi le passe câble en caoutchouc souple à l'entrée pour s'adapter à tous les diamètres sans être obligé de recouper.
This review has been posted for ELECAUDIO CH-22G Sector plug Switzerland SEV 1011 Silver + Gold Ø17mm
