This Dynavox Phono Preamplifier will let you enjoy your MM/MC Scanning System turntable simply.
Phono MM/MC Preamplifier
The TC-2000 is the latest phono preamplifier from Dynavox for vinyl turntable with MM or MC scanning system. This ensures high sound quality at a low price. In addition, its rugged metal housing and external power source greatly reduces interference that could degrade the signal. The preamplifier also has the MM-System 2, which allows the input impedance to be adjusted via the switch.
Frequency response | 20Hz - 20kHz (+/- 0.5dB) |
Voltage output | 200mV 1kHz |
THD | < 0.0005% |
Input sensibility | MM I & II : 4mV 1kHz MC : 0.45mV 1kHz |
SNR | MM I & II : >88dB MC : >78dB |
Input impedance | MM I : 47kΩ 100pF MM II : 47kΩ 300pF MC : 100Ω 100pF |
Input | 1x RCA |
Output | 1x RCA |
Power supply | 12-16V / AC - 150mA |
Weight | 0.5kg |
Dimensions | 145 x 55 x 125mm |
Parts supplied | |
TC-2000 | x1 |
AC adapter | x1 |
