FX-AUDIO BOX01 Preamplifier Vinyl player (MM) NJM2068 Black
FX Audio BOX01
This FX-Audio BOX01 preamplifier is designed exclusively for use as an output from a source with a mobile magnet phono cell (vinyl player).
4.6 / 5
Reference : 13197
44,90 €tax incl.
37,42 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
BOX01 Vinyl player Preamplifier
308mVrms / NJM2068 / -75dB SNR THD 0.008%
Preamplifier recovery drive Phono Audio FX Signal
This controller is exclusively designed for use at the output of a source equiped with a magnetic cell (vinyl player).
Its function is to amplify the signal from your turntable before volume control and amplification.
 Ideally, it will be connected to an integrated amplifier bringing volume control and power amplification altogether. Alternatively, it may be incorporated into a configuration where the preamplifier-volume controller precedes a power amplifier.
Preamplifier NJM2068
phono preamp audio fx
This phono preamplifier operates through a high performance,low noise two-way preamplifier NJM2068.
This component is designed for applications requiring high sensitivity processing signals in an environment requiring very low noise.
The NJM2068 has excellent specifications for a phono preamplifier application with distortion barely correlated to the device temperature variations, a wide bandwidth (27MHz), a THD of 0.001% and a slew rate of 6V / microseconds.
Working in concert with a series of well-placed capacitors in a very clean design, AOP NNJM 2068 meets all the conditions to offer a clear, accurate sound with any vinyl player.
Easy Installation & ground connector
Vinyl phono preamp drive signal rectifier platinum
Installation is made simple with easy access and well arranged rear panel.
Simply connect the input of the device to your vinyl player with a stereo RCA connector and connect the output to an integrated / pre-amp amplifier via the same connector type.
ChipNJM2068
RMS level308mVrms
SNR-75dB
THD0.01%
InputStereo RCA (phono MM)
Power-SupplyDC 12V 1A
Dimensions130 x 100 x 35 mm
Weight0.31kg
Parts supplied
Audio FX BOX 01x1
Power supply (SMPS)x1
InputPhono
ClassN/A
14 reviews
Super
Branché sur une platine Rega Planar One, il assure complètement le job et cela pour un prix défiant toute concurrence. Comme d’habitude avec Audiophonics, expédition très rapide et soignée.
This review has been posted for FX-AUDIO BOX01 Preamplifier Vinyl player (MM) NJM2068 Black
pat 54
je ne m attendais pas a une telle ecoute a ce prix.tres bon service merci
Incroyable
Très très bonne surprise, ce petit préampli Riaa, est bluffant de qualité, très bon gain, bonne bande passante, et, absolument silencieux, pas le moindre souffle, ou ronflette !!!
Je le recommande, à ce prix là, i n'a aucun concurrent !!!
Bon produit
Parfait pour un petit système d'appoint , fait le job
réponse tardive à Jean b.
Je viens seulement de voir votre message, j'ai remplacé le condensateur électrochimique 16V 2200 uF par 2 Nichicon 16V 1000 uF FG (Fine Gold) bien meilleurs en terme de dynamique et de musicalité. Cordialement !
