Polypropylene Capacitor 5mm 63V 220pF
These WIMA FKP-2 capacitors are made of a Polypropylene dielectric. They benefit from a tolerance of 2.5%, a very low dissipation factor and a low level of dielectric absorption. Their filtering capacity allows them to be used in a wide range of applications. Moreover, they have an extended service life, even at high temperatures.
Product type | Capacitor |
Capacity | 220pF |
Voltage | 63VDC 40VAC |
Tolerance | 2.5% |
Dielectric | Polypropylene foil (PP) |
Electrodes | Metal foil |
Temperature range | -55°C to +100°C |
Insulation resistance (@+20°C) | ≥ 5x105MΩ |
Dielectric absorption | 0.05% |
Operational life | > 300000h |
Dissipation factor (@ +20°C) | ≤ 3x10-4 @ 1kHz ≤ 3x10-4 @ 10kHz ≤ 4x10-4 @ 100kHz ≤ 10x10-4 @ 1MHz |
RoHS |
Dimensions | 4.5 x 6 x 7.2mm |
Contacts spacing | 5mm |
Tolerance (%) | 2.5 |
Capacitor capacitance | 0.00022 |
Rated voltage (V) | 63.0 |
Capacitor type | Film capacitor |
Capacitor format | Radial |
