Bluetooth Audio Wall receptor to RJ45 Source Keypad
This wall module incorporates a Bluetooth receiver allowing the signal to be conveyed over a CAT6 cable to an RJ 45 / RCA converter. All you have to do is pair your compatible smartphone or tablet (laptop) with the "pairing" button on the built-in front.
Reference : 11086
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
It is thus possible to integrate Bluetooth technology discreetly into the recessed wall and convey the sound via an RJ 45 cable concealed in the partitions and connect its traditional Hi-Fi system with the proprietary RJ45 / RCA module.
The module RJ45/RCA can be found here : Fiche 11085.
Datasheet:
Wall-mounted Bluetooth module with pairing button.
Dimensions :
 12,5 x 8 cm
Fixing center distance : 10 cm
OutputRJ45
DAC / ADC ChipNC
ColorSilver
Supported Bluetooth codecsN/A
This wall module incorporates a Bluetooth receiver allowing the signal to be conveyed over a CAT6 cable to an RJ 45 / RCA converter. All you have...
