WiFi Bluetooth 5.0 Receiver AirPlay 2 DLNA Multiroom
The CloudyX CL-Box is an extremely practical WiFi and Bluetooth receiver combo, allowing you to transform your audio installation into a true wireless system. Compact and stylish, it offers excellent performance and intuitive remote control.
The conversion stage of the CL-Box uses a 24bit AKM AK4430 DAC chip. This benefits from an intelligent architecture that ensures very good audio performance, including a wide dynamic range, excellent linearity and low THD+N.
Compatible with Amazon multiroom and LinkPlay, the CL-Box will allow you to easily stream your music throughout your home. Its control application allows it to manage playback for each receiver in your different rooms.
The CL-Box receiver can be remotely controlled via your smartphone with the free Müzo Pod application, available for Android and iOS. The latter allows you to manage the playback and distribution of your music for each CL-Box module installed. Moreover, the application is compatible with the most popular streaming services such as Spotify, Qobuz or Deezer.
Product type | WiFi Receiver |
Connectivity | WiFi 2.4G & 5G Bluetooth 5.0 1x RJ45 (Ethernet) |
Outputs | 1x Jack 3.5mm 1x Optical Toslink |
DAC Chip | AKM AK4430 |
WiFi Standard | 802.11 b/g/n |
Supported WiFi protocols | AirPlay 2 DLNA |
Ethernet type | 10/100Mbps |
Output sensitivity | Jack 3.5mm output : 2V (1kHz 0dB) Optical output : 0dB (1kHz 0dB) |
Frequency response | 20Hz - 20kHz |
THD | 0.03% |
SNR | 95dB |
Infrared receiver | |
Multiroom compatibility | Amazon LinkPlay |
Supported streaming services | Spotify Qobuz Deezer Tidal Napster iHeartRadio ... |
Power supply | 5V DC via USB-C |
Color | Black |
Dimensions | 140 x 125 x 30mm |
Package | 1x CloudyX CL-Box 1x Power adapter 5VDC 2A 1x USB-A to USB-C cable 1x Jack 3.5mm cable |
Input | Bluetooth |
Input | WiFi |
Input | RJ45 |
Output | Optical Toslink |
Output | Bluetooth |
Output | Jack 3.5mm |
Output | WiFi |
Color | Black |
Transmission / Reception protocol | AirPlay |
Transmission / Reception protocol | Bluetooth |
Transmission / Reception protocol | Ethernet |
Transmission / Reception protocol | DLNA |
Transmission / Reception protocol | IR |
Transmission / Reception protocol | WiFi |
