DAYTON AUDIO WFA02 MultiRoom Wi-Fi Audio Adapter for iOS Android DLNA
DAYTON AUDIO WFA02 Multi-Room Wi-Fi Audio Adapter for iOS Android
Reference : 10538
59,90 €tax incl.
49,92 € tax excl.
Shipping from France
Billing in France
Technical support in France
Take advantage of the multi-room experience and free music distribution at home with this WFA02 Wi-Fi receiver developed by Dayton Audio.
This receiver transforms your current speakers or stereo system into a versatile and powerful system of music streaming and online radio.
Features:/ Strong>
  • Supported Protocols: DLNA, Airplay
  • Wi-Fi 801.11 b / g / n
  • Frequency response: 20 Hz - 22 kHz
  • Stereo Analog Input Jack 3.5mm
  • Stereo Analog Output Jack 3.5mm
  • Ethernet RJ45 port
  • USB Port Type A
  • Power supply via micro USB 5V DC 500mA
  • Dimensions: 75x75x17mm
  • 75 g
  • Compatible with Mac OS, iOS, Android, Windows
  • USB to A to Micro USB Cable and 3.5mm to 3.5mm Jack Cable
Your Hi-Fi system redefined.
This super-compact receiver is easy to use, connecting to your existing speakers is fast.
Read the excellent test of Qobuz
test Dayton WFA02
Dayton Audio WFA02
Multi-Room: Synchronized audio playback in multiple rooms.
Dayton Audio WFA02
Milti-Channel: Listen to your audio files on independent devices or on a group of devices simultaneously.
Dayton Audio WFA02
Multi-User: Different users can control the audio source on different devices in the home network.
Extend your audio listening experience with Dayton Audio's new Hi-Fly ™ multi-room Wi-Fi technology.
With the Hi-Fly application, you can stream your favorite music online, listen to music directly from your device (Smartphone, Tablet, etc ...), play music stored on your computer at home or via USB connected directly to the back of the WFA02.
Theimplementation of WFA02 is simple, start by downloading the free Hi-Fly ™ application from Dayton on: //play.google.com/apps? hl = en "target =" _ blank "> Play Storeor the "Apple Store.Once the application is installed, open it on your mobile device or tablet and follow step by step. If you are using a wired connection, the application instructions are not required; just open the application and your device is ready to use.
Dayton Audio WFA02
The Dayton Audio Hi-Fly ™ application turns your mobile device or tablet into a remote control for all Dayton Audio Hi-Fly ™ devices enabled.
Jstream music from your favorite streaming platforms like Pandora and Spotify, from your home network or mobile device.
Avec Hi-Fly, you can send music to each WFA02, or group your Hi-Fly enabled systems together for true multi-room audio playback.
Also, your music continues to play even if your phone is turned off or you need to take a call.
InputJack 3.5mm
InputWiFi
InputRJ45
OutputJack 3.5mm
Petite boîte qui envoie bien!
Il mérite 5 étoiles, je m'attendais pas un tel exploit,sans agressivité avec une once de douceur,la musique coule!
This review has been posted for DAYTON AUDIO WFA02 MultiRoom Wi-Fi Audio Adapter for iOS Android DLNA
