FX-AUDIO BL-MUSE-03 Bluetooth Receiver 4.2 aptX NFC aptX CRSA64215 & Heapdhone Amplifier
FX-AUDIO BL-MUSE-03 Récepteur Bluetooth 4.1 Aptx NFC
The FX-Audio upgrades its BL-MUSE-02 to make room for the BL-MUSE-03. Maintains a high level of quality, whether in the design or component selection, while offering new features and improved performance
POINTS CLÉS :
  • Bluetooth Chip 4.2 AptX CSRA64215
  • A2DP, AAC, SBC
  • DAC AKM AK4452VN
  • Headphone Amplifier Maxim MAX9722
4.8 / 5
Reference : 12433
54,90 €tax incl.
45,75 € tax excl.
Shipping from France
Billing in France
Technical support in France
FX-AUDIO BL-MUSE-03
4.2 Bluetooth Receiver NFC & Headphone Amplifier
FX-Audio BL-Muse-03 Récepteur Bluetooth
An efficient evolution
The FX-Audio upgrades its BL-MUSE-02 to make room for the BL-MUSE-03. This maintains a high level of quality, whether in the design or component selection, while offering new features and improved performance.
Bluetooth 4.2
The first size change, the supported Bluetooth standard is now 4.1 to 4.2. A more secure, faster and more energy-efficient version of Bluetooth. In this case, the BL-MUSE-03 achieves higher performance than its predecessor.
Complete connectivity
The BL-MUSE-03 comes with a full output connector to adapt to individual needs. This includes a Coaxial RCA, a Stereo RCA, and a Toslink Optics. In addition, an antenna ensures the transmission quality and the power supply of the device is via its Micro USB connector (power supply provided).
FX-Audio BL-MUSE-03 Connectique complète
Qualcomm BlueCore CRSA64215 Bluetooth Chip
To ensure excellent Bluetooth transmission quality, the FX-Audio BL-MUSE-03 comes with a Qualcomm BlueCore CSRA64215 4.2 standard chip. It is designed for audio applications and supports A2DP, SBC and AAC technologies.
FX-Audio BL-MUSE-03 DAC AK4452VN
AKM AK4452VN DAC
The DAC AKM AKM AK4452VN is a new-generation DAC with the Velvet Sound Archive, widely used for high-end audio devices. This technology achieves a very high level of detail with very low distortion and noise, while taking advantage of a 32-bit digital filter.
Maxim MAX9722 Amplifier
To ensure that the BL-MUSE-03 is a headset amplifier, the BL-MUSE-03 is based on a Maxim MAX9722 amplifier chip. This system integrates a noise cancellation system and ensures a THD of 0.07%, a SNR of 90dB and 200mW power.
Bluetooth
Bluetooth ChipQualcomm BlueCore CSRA64215
Bluetooth Version4.2 / AptX
Modulation methodπ / 4 DQPSK, 8DPSK
Supported Bluetooth ProtocolsSBC
AAC
HFPV 1.6
HSP V1.2
A2DP V1.3
AVRCP V1.6
DIV 1.3
Transmission distance10m
Transmission powerClass 1 / Class 2 / Class 3
Frequencies-12.4GHz - 2.480 GHz
Amplifier / DAC
Sensibilité-92dbm DQPSK Receiver
-82dbm 8PSK Receiver
DACAKM AK4452VN
Headphone amplifier chipMaxim MAX9722
Sample rate24bit 48kHz
THD0.06%
Headphone Output THD0.07%
SNR93dB
Headphone OutputSNR90dB
Headphone output power200mW
Connectors : Outputs
Optical Toslink1x
Coaxial RCA1x
RCA Stereo1x
Jack 6.35mm1x
Power SupplyMicro USB 5V 1A
Dimensions150 x 98 x 33mm
Weight292g
Package1x FX-Audio BL-MUSE-03
1x Power Supply
1x Antena
OutputOptical Toslink
OutputCoaxial SPDIF
12 reviews
what else
fait le Job, parfaite connexion stable et de bonne qualité audio donc pourquoi dépenser plus, merci Audiophonics, envoi rapide et soigné
This review has been posted for FX-AUDIO BL-MUSE-03 Bluetooth Receiver 4.2 aptX NFC aptX CRSA64215 & Heapdhone Amplifier
Super rapport qualité prix
C'est le deuxième que j'achète et ce n'est pas sans raison.
Je n'utilise pas la sortie casque mais soit la sortie digitale optique en le branchant sur un serveur multi-média Pioneer N-50 (plutôt haut de gamme pour ceux qui ne connaissent pas) ou directement sur une entrée ligne du pré_ampli.
Surprise le son de la sortie ligne soutient la comparaison avec la sortie du Pioneer, clair, dynamique un bon grave. sur Deezer avec une bonne connexion WiFi et avec une téléphone Sony XPeria une écoute très agréable et sans fatigue.
Si vous utilisez la sortie RCA, pensez que son niveau de sortie dépend de la position du bouton de volume, ce qui permet de la régler au même niveau que les autres sources utilisées.
Je vais sans doute l'intégrer dans mon pré-ampli maison, en tant qu'entrée Bluetooth là il aura une alimentation de course et ça évitera la multiplication des boîtiers, câbles et autres alim.
Bref à ce prix là et m^me plus cher j'ai pas trouvé mieux.
satisfait
excellente qualité audio. envoi hyper rapide et soigné
un boîtier passe partout
Excellent petit boîtier récepteur Bluetooth, la sortie en analogique permet avec le potentiomètre d'obtenir un niveau sonore variable très pratique, de ce fait, il se comporte comme un pré amplificateur et l'on peut aborder directement un ampli de puissance sans soucis, d'ailleurs la courbe d'évolution du son est assez progressive grâce au potentiomètre qui possèdent un grand nombre de palier pour un réglage précis du volume sonore souhaité.
Les 2 autres sorties numériques sont utiles et bien pratique pour utiliser un DAC ou tout autres périphériques possédant ces 2 types d'entrées.
Je n'ai pas eu de problème de déconnexion comme l'a signalé Romain B, à savoir que j'ai acheté 2 exemplaires du FX-AUDIO BL-MUSE-03, le premier que j'ai offert à mon neveu car j'ai considéré que ce maillon était indispensable pour aller avec son ampli Harman Kardon HK980 d'ailleurs le son est somptueux avec ! et le deuxième exemplaire était pour moi !! sur les 2 MUSE j'ai rencontré aucun soucis et ceci en utilisant diverses sources émettrices.
Il existe à ce jour plusieurs niveaux de qualité entre les émetteurs Bluetooth, si vous avez toutefois des déconnexions intempestives avec le FX-AUDIO BL-MUSE-03, il n'en sera pas la cause et il vous faudra chercher plutôt à la source ! soit l'émetteur.
La qualité de restitution sonore en utilisant la sortie analogique est d'un excellent niveau, d'ailleurs je ne pensais pas avant cet achat obtenir un tel résultat à partir de ce récepteur Bluetooth, une agréable surprise ce petit module.
Je vous le conseille
Produit reçu rapidement et mis en service en 2 minutes. Le WI FI à une connexion rapide et le son est vraiment fidèle.
Je l'ai branché sur mon ampli par la fibre optique et je lis principalement Deezer via mon smartphone One plus OPT3.
Je vous le recommande.
The FX-Audio upgrades its BL-MUSE-02 to make room for the BL-MUSE-03. Maintains a high level of quality, whether in the design or component...
