SMSL Remote control for amplifier FDA AD18 / Q5 Pro
Sure Universal Remote Control Black
This infrared remote control is dedicated to the exclusive use of the main functions of the FDA SMSL AD18 amplifier and Q5 Pro. It is ideal as a replacement for the original model in the event of a malfunction or as a second auxiliary remote control.
Reference : 12515
9,90 €tax incl.
8,25 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
- SMSL AD18 & Q5 Pro Remote control -
This SMSL remote control is fully compatible with the main functions of the FDA SMSL AD18 amplifier and Q5 Pro. It allows you to navigate through menus, manage the volume, select input sources and EQs. It is similar in every respect to the original remote control.
It is ideal for replacement in case of defective original remote control or as an auxiliary remote control.
Compatible with SMSL devices. Please refer to the manual of each device to know the linked pairing key (A, B, or C).
Features :
  • Range Angle: 30°+30°+30° Range
  • Dimensions: 150x38x14mm
  • Weight: 36g
  • Material: ABS
  • Colour: black
  • Requires two 1.5V AAA batteries not included
InputNC
OutputIR
Transmission / Reception protocolIR
Mieux que la télécommande d'origine
Fonctionne parfaitement avec l'ampli/DAC SMSL Q5 pro, en remplacement de la télécommande d'origine peu fiable.
Elle mesure 15 cm, et on y retrouve toutes les fonctions, y compris la sélection des modes Equalizer qui ne peut se faire que par télécommande (touche FN ici).
This review has been posted for SMSL Remote control for amplifier FDA AD18 / Q5 Pro
This infrared remote control is dedicated to the exclusive use of the main functions of the FDA SMSL AD18 amplifier and Q5 Pro. It is ideal as a...
