XH 2.54mm Female / Female Cable 3 Poles 2 Connectors Shielded Gray 15cm (Unit)
XH 2.54mm Shielded Cable with 3 Poles Connectors Gray 15cm (Unit)
This good quality shielded cable has two XH 2.54mm 3 pole connectors. It will allow you to mount more easily and quickly on your PCBs that also have XH connectors. In addition, the cable shielding reduces interference and the noise generated by it.
Reference : 13020
0,80 €tax incl.
0,67 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
Câble XH 2.54mm
Shielded cable, 3 poles connector, 15cm (Unit)
Câble XH 2.54mm
Cable type2x XH 2.54mm 3 poles
Connector plug spacing2.54mm
Length15cm
ShieldingYes
Cable diameter2.8mm
Section28AWG
ColorGray
Sold individually-
ColorGray
Length (m)0.1
ConnecticFemale
Contacts number3
This good quality shielded cable has two XH 2.54mm 3 pole connectors. It will allow you to mount more easily and quickly on your PCBs that also...
