EIZZ EZ-206 XLR Gold Plated 3 Way Female XLR Connector PTFE Ø9mm Black (Unit)
EIZZ XLRConnector XLR Female 3 Pins PTFE Gold Plated Ø 9mm (Unit) Black
This XLR EIZZ connector with PTFE insulation allows the design of XLR balanced quality cables. Its gold-plated finish and seamless screw terminal blocks ensure first-rate contact.
Reference : 12391
22,90 €tax incl.
19,08 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
EIZZ XLR PTFE
without Soldering
This gold-plated 3-pin XLR connector with PTFE insulation features an excellent finish with screw terminals that avoid tin soldering on the hot-spot, cold-spot and ground connectors. It is therefore ideal for designing high quality AES / EBU cables.
Its 24K gold plating, its internal PTFE insulation in the background is an excellent candidate for quality cables at reasonable cost.
XLR EIZZ PTFE TEFLON
Technical caracteristics
XLR EIZZ EZ206F CONNECTOR
TypeXLR FEMALE
material conductorBronze Phosphorus
Insulated materialPTFE
Acceptable cable diameter8mm with clamping ring, 9mm without clamping ring
external body MaterialAluminium alloy and Chrome plated
Divers
Length and diameter52.2mm / 19mm
QuantitySold per unit
Weight26g
Insulation materialPTFE
Max cable diameter (mm)9.0
Mounting typeTo weld
Mounting typeTo screw
ConnecticFemale
Contacts number3
ConnectorXLR
5 reviews
chauchau
Connecteur à vis très serieux et montage facile pour les personnes qui sont contre les soudures. En cherchant mieux vou s risquez de trouver plus mal. Merci Audiophonics pour le rapport qualité-prix.
This review has been posted for EIZZ EZ-206 XLR Gold Plated 3 Way Female XLR Connector PTFE Ø9mm Black (Unit)
EIZZ XLR
le produit est de bonne qualité , l'avantage ,est la liaison vissée , donc pas de soudure . En prenant en compte le tarif , ce produit est bien positionné sur la grille
efficace et prix justifié par sa qualité
Excellent produit : placage or de bonne qualité car il ne s’écaille pas comme sur certaines autres marques asiatiques, les pas de visse sont sans jeux, visses sans tête en acier de bonne qualité. Bref un produit parfaitement recommandable. Je les ai montées sur du câble ELECAUDIO SC-221SPOFC dont chaque brin a une section de 0.12mm. Toutefois, pour visser les câbles, il faut avoir une clé Allen (6 pans) type 82H de 1.3mm, disponible au rayon bricolage ou chez les marchands de cigarettes électroniques ou de modélisme et chez votre voisin « Vapoteur », car elle fait partie du nécessaire de montage des réservoirs DTA et RDTA.
Bon DIY...
Connecteur facile a monter, grâce au système de vissage. Bonne qualité, un produit de qualité, a recommander. Attention a la clef allen a
utiliser de 1,27 mm, que l'on trouve sur le site, car cette dimension ne court pas les rues.
Très bien
Belle connectique de qualité, ça faisait un moment sue je voulais essayer un produit sans soudure afin d'avoir "un intermédiaire" de moins, et le résultat est fructueux, sur le câble haut de gamme que j'ai dépecé (Burmester Silver) en enlevant ses prises de qualité soudées j'ai eu un petit gain for t sympathique à l'écoute :)
This XLR EIZZ connector with PTFE insulation allows the design of XLR balanced quality cables. Its gold-plated finish and seamless screw terminal...
