Pas trop de référence à comparer, puisque c' est mon premier diy en xlr. Fait ce qu'il faut !!
Male 3 pin XLR Gold Plated Tellurium Copper Ø 8.5mm (Unit)
This Elecaudio CX-101 3 pin male XLR connector benefits from a high quality design thanks to the use of high quality material. We thus find Tellurium copper contacts for high conductivity, gold plated to ensure resistance to oxidation.
In addition, the metal structure of the connector ensures great durability to the connector.
Connector type | Male 3 pins XLR |
Contacts material | Tellurium Copper |
Contacts plating | Gold |
Connection type | Soldering |
Max. cable diameter | 8.5mm |
Dimensions | 50 x 19mm |
Insulation material | PE |
Max cable diameter (mm) | 8.5 |
Mounting type | To weld |
Connectic | Male |
Contacts number | 3 |
Connector | XLR |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Gold |
Average votes 4.9 / 5 8 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Cedric J.
BEATRIZ H.
Gérard D.
Nico V.
Andy H.
