ELECAUDIO CX-102 Gold Plated 3 Way Female XLR Connector Ø8.5mm (Unit)
ELECAUDIO EX-102 Female 3 Pins XLR Connector Gold Plated Ø 8.5mm (Unité)
This Elecaudio CX-102 3-pin female XLR connector has a quality design with gold-plated Bronze Phosphore contacts.
4.9 / 5
Reference : 12540
7,90 €tax incl.
6,58 € tax excl.
Shipping date: 23-04-2024.
Shipping from France
Billing in France
Technical support in France
ELECAUDIO CX-102
Female 3 pins XLR Gold plated Bronze Phosphore Ø 8.5mm (Unité)
elecaudio connecteur xlr femelle 3 pins plaqué or
This Elecaudio 3 pin female XLR connector benefits from a high quality design thanks to the use of high quality material. We thus find gold-plated Bronze Phosphore contacts ensuring good conductivity and high resistance to oxidation.
In addition, the metal structure of the connector will ensure great durability. A lug ensures the good maintenance of the connector once connected.
Connector typeFemale 3 pin XLR
Contacts materialBronze Phosphore
Contacts platingGold
Connection typeSoldering
Max. cable diameter8.5mm
Total dimensions63 x 23mm
Insulation materialPE
Max cable diameter (mm)8.5
Mounting typeTo weld
ConnecticFemale
Contacts number3
ConnectorXLR
7 reviews
Pas facile ces demoiselles !
Certe, c' est mon premier diy, mais je déconseille aux débutants en soudure, ce qui est mon cas.
Il faut savoir souder vite au risque de voir les pattes de fixation se désolidariser du châssis en plastique.
Sinon, elles sont jolies et fonctionnelles.
This review has been posted for ELECAUDIO CX-102 Gold Plated 3 Way Female XLR Connector Ø8.5mm (Unit)
very good product
Paul
Hi , nice plugs and easy to solder . Thank you
Nick
Light weight XLR plug but the materials they use are excellent
Nice XLR connectors
Hi, Salut, Nicely made simple connectors. Inexpensive, easy to work with and light weight aluminum body. **Care must be taken when soldering. Be quick as the contact support plate can be melted easily**
