By buying this product you get 27 loyalty points
High-performance male XLR plug to be welded, with 24k gold-plated contacts. Central conductor Beryllium copper and phosphor bronze treated by the proprietary antimagnetic process FURUTECH Alpha α.
The Alpha technology involves 2 steps:
1-Cryogenization of metals by -250 ° C with the aid of liquid nitrogen in order to consolidate their molecular structure and to improve their conductivity significantly.
2- Submission of these same metals to a powerful magnetic field created by means of magnets arranged in rings and whose attraction force is constantly controlled so as to leave no residual magnetic at the end of the treatment.
Copper alloy body and Teflon insulation whose mouth is provided can receive cables with a maximum diameter of 12 mm.
Features:/ Strong>
Insulation material | PE |
Max cable diameter (mm) | 12.0 |
Mounting type | To weld |
Connectic | Male |
Contacts number | 3 |
Connector | XLR |
Contacts Material (Connector) | Copper Alloy |
Contacts Material (Connector) | Beryllium Copper |
Contacts Plating (Connector) | Gold |
