NEUTRIK NC3MRX 90° Angled Silver Plated 3-Pole Male XLR Connector Ø8mm (Unit)
Neutrik NC3MRX XLR Male 90° Silver plated Ø 8mm (Unit)
This Neutrik NC3MRX RX series connector is a 90° angled male XLR connector. It features a nickel-plated copper alloy body and silver-plated copper alloy contacts for protection against corrosion and oxidation. It accepts cables with a minimum external diameter of Ø3.5mm to a maximum of Ø8mm. Cable assembly is performed by soldering with conductors of up to 2.5mm² (14AWG) cross-section.
Reference : 792
7,90 €tax incl.
6,58 € tax excl.
Shipping date: 29-03-2024.
Shipping from France
Billing in France
Technical support in France
NEUTRIK NC3MRX
This Neutrik NC3MRX RX series connector is a 90° angled male XLR connector. It features nickel-plated copper alloy body and silver-plated copper alloy contacts for protection against corrosion and oxidation. It accepts cables with a minimum external diameter of Ø3.5mm to a maximum of Ø8mm. Cable assembly is performed by soldering with conductors of up to 2.5mm² (14AWG) cross-section, while overall connector assembly requires no screws for added convenience. In addition to convenient assembly, 7 cable outlet positions are selectable. This high-quality male XLR connector also features a highly effective cable clamp, solder barriers on its internal contacts and low resistance on its external contacts for enhanced conductivity. Grounding is also optimized thanks to spring-loaded contacts ensuring continuity with the connector body.
Product type90° XLR male connector
Capacitance between contacts≤ 4 pF
Contacts resistance≤ 3mΩ
Dielectric strength1.5kVcc
Insulation resistance> 2GΩ (initial)
Rated current per contact16A
Rated voltage< 50V
Min/max eternal cable diameterØ3.5 to Ø8mm
Max. cable cross-section2.5mm² (14AWG)
Mounting typeTo weld
Body materialCopper alloy
Body platingNickel
Contacts materialCopper alloy
Contacts platingSilver (2µm)
Operating temp.-30 °C to +80 °C
Total dimensions69.3 x 38.5 x Ø19mm
Weight54g
Package1x NEUTRIK NC3MRX male 3-pole 90° angled XLR connector
Insulation materialPE
Max cable diameter (mm)8.0
ConnecticMale
Contacts number3
ConnectorXLR
This&nbsp;Neutrik NC3MRX RX series connector&nbsp;is a&nbsp;90&deg; angled&nbsp;male XLR connector.&nbsp;It...
