RAMM AUDIO 60200-GT Gold Plated Tellurium / Berrylium Copper 3 Way Female XLR Connector Ø11mm (Unit)
Ramm AUDIO Connecteur XLR femelle 3 pin Gold plated Pure Copper Ø 11mm (Unit)
Reference : 9454
52,90 €tax incl.
44,08 € tax excl.
Shipping from France
Billing in France
Technical support in France
This Ramm AUDIO XLR connector is made from carefully selected materials.
It is a very robust and high quality connector.
The conductor is made of Cryo-treated Copper Tellurium and Gold Plated Berrylium with Teflon insulation and a clean design with impeccable finish.
Features:
  • Conductor: Cryo-treated Copper Tellurium and Gold Plated Berrylium
  • Gold plated 3-pole Female XLR connector
  • Brass body
  • Teflon insulation
  • Acceptable cable diameter: 11mm
  • Screw on
  • Dimensions: 57x19mm
  • Weight: 35g
  • Sold individually
Insulation materialPE
Max cable diameter (mm)11.0
Mounting typeTo screw
ConnecticFemale
Contacts number3
ConnectorXLR
Contacts Material (Connector)Beryllium Copper
Contacts Material (Connector)Tellurium Copper
Super rapport qualité - prix
Cable à visser, sonorité et rapport qualité prix au top.
Mais attention toutefois aux trous qui ne conviennent pas aux cables de forte section comme les Elecaudio OCC FEP et les vis où la plus petite clé Allen de 1.5 mm ne rentre pas. Ni des instructions de montage ni de clé ne sont fournis mais j'ai finalement réussi à visser avec une Torx T5. Je maintiens 5 étoiles pour le premier point.
This review has been posted for RAMM AUDIO 60200-GT Gold Plated Tellurium / Berrylium Copper 3 Way Female XLR Connector Ø11mm (Unit)
