VIBORG CM201 (R) 3 Poles Male XLR Panel Plug Silver / Rhodium Plated Pure Copper (Unit)
VIBORG CM201 (R) XLR Male Pure Copper Plated / Rhodium (Unit)
This 3-pole XLR male Viborg CM201(R) XLR base has an exemplary design thanks to the use of the best materials. Indeed, the contacts of the base plate are made of 99.998% pure Copper to ensure an excellent conductivity of the audio signal. The contacts are also silver and rhodium plated.
Reference : 13361
21,90 €tax incl.
18,25 € tax excl.
Shipping date: 02-04-2024.
Shipping from France
Billing in France
Technical support in France
Viborg CM201(R)
Viborg CM201(R) Embase XLR Mâle Cuivre Pur Plaqué Argent / Rhodium (Unité)
This 3-pole XLR male Viborg CM201(R) XLR base has an exemplary design thanks to the use of the best materials. Indeed, the contacts of the base plate are made of 99.998% pure Copper to ensure an excellent conductivity of the audio signal. Contacts that also benefit from a double silver and rhodium plating. Silver being the best conductor, it allows to maximize the transmission performance of the base plate, where Rhodium will protect the contacts from corrosion and thus considerably extend its life span.
Product typeMale XLR panel plug
Number of pins3 pins
Contacts materialPure Copper
Contacts platingSilver / Rhodium
Body materialCNC machined Aluminium alloy
InsulationPTFE
Total dimensions26 x 31mm
Cutout diameter21.2mm
ColorGray
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
Contacts number3
Max panel thickness (mm)N/A
ConnectorXLR
This 3-pole XLR male Viborg CM201(R) XLR base has an exemplary design thanks to the use of the best materials. Indeed, the contacts of the base...
