christian b.
Il était temps...
Acheté pendant le confinement j'avais décidé de tester le changement du câble secteur sur mes électroniques. Plutôt...
Cheung T.
Excellent cable
This is an excellent cable for high end audio. Although it is mentioned to have 50 strands of 0.25mm wire, I can only find 48...
Pascal A.
Exceptionnel
Je l'ai acheté ici il y a quelques mois. Incroyable. Rapport qualité prix bousculant beaucoup de references beaucoup, mais...
AUDIOPHONICS LPSU25 Alimentation Linéaire Régulée Faible Bruit USB 115V vers 5V 2A 25VA - avis - Il y a 1 avis.
Fernando P.
Compact, well-designed supply
I had been using a bulkier, much more expensive linear power supply for a standalone Pi music streamer (Pi 2 + touchscreen + S/PDIF output hat). That other supply worked well, but I was intrigued when I saw this LPS. The order process and delivery to the US were fast and efficient. When I set the supply with the intended system, the touchscreen signaled low voltage. It took me a while to notice the brief text on the website about the (very small) voltage adjustment screw. After adjusting the screw, the under-voltage is gone. Overall, a good product at a good price, but it would be nice to have better documentation about voltage adjustment/voltage range.
 (5)
Voici l'alimentation régulée 5V 2A audiophile pour tout appareil fonctionnant sur port USB. Elle est...
