Noel C.
Andrea T.
excellent
Rien de spectaculaire...
Vasileios K.
A great dac for the money
AUDIOPHONICS LPSU100 Alimentation Linéaire Régulée 19V 5.25A 100W NAS / Intel Nuc - avis - Il y a 16 avis.
Jacques T.
Belle alimentation
J ai acheter cette alimentation pour couper un boucle de masse et surtout pour alimenter correctement un mini PC dédié a l'audio.
Le résultat est la...plus de boucle de masse. Mon système est devenu parfaitement silencieux et les alimentation du pc rien avoir c est propre et silencieux.Le 5V des ports USB et maintenant bien régulé.
isolation galvanique et alim linéaire parfaitement régulee..c est la base du silence
Mike d.
Excellent
Fast delivery. Excellent device.
Suggestions:
1. offer a black faceplate as alternative
2. the psu is over dimensioned for a single intel nuc or intel-nuc-based-audio-device. Consider providing a second 19v output and second cable (as a bookshelf option?).
Andre L.
Very good quality and solidly built power supply
Packaging was very good (double boxed and good protection foam inside). The power supply is much bigger and heavier than I imagined, but that is good.
Solidly built, good solid connections and works perfectly with my NUC8.
Christian M.
Alimentation faible bruit
Très bonne performance de cette alimentation utilisée dans un domaine de réception radio où son faible bruit de fond est remarquable.
La finition est top et son rapport qualité/prix excellent.
Fonz V.
Great Power Supply. Great Service
Thanks Audiophonics for the great service and quick delivery of the Power Supply. It's a perfect combo with the Intel NUC and Roon Rock. The power amp does not get warm at all. Sound has more detail and a more relaxed bass. Only minor thing to me is that the red light at the front is 2 strong for my taste.
Matthias K.
Fantastic linear power supply
I can fully confirm everything that has been written about the power supply in other positive reviews.
The benefits of the power supply for a music computer with Roon Rock (in my case Prime Mini i7, DA converter from La Rosita) are unmistakable. I could not imagine such a good performance. The music plays in front of a darker background, more space, improved sound colours, clearly higher dynamics, more space between the instruments, more details over the entire frequency range, bass more contoured, voices stand more freely in the room. All in all, a top unit. Price and performance are right.
Many thanks to the Audiphonics team, service and purchase were first class. Contrary to the product description, a mains cable was also included. A nice extra service.
Gerard G.
Substantial improvement of sound quality
Connected to my Intel NUC with Roon Rock it resulted in a serious improvement of the sound quality of my Roon environment. More dynamics, a bigger sound stage, a beter definition in the middle and high frequenty range and a more convincing base. A highly recommended tweak! Use also a high quality power cable for an even beter result.
 (4)
GILBERT C.
LPSU100
Bel objet bonne qualité mon intel nuc chante mieux avec cet alim juste cette led rouge trop brillante qui me gene mais ce n'est qu'un détail...
Yannick B.
Magique .
Ce joli petit bloc massif branché sur mon Smsl Q5pro est une merveille.L'alimention parfaite pour le petit ampli qui devient d'un coup un véritable ampli haut de gamme.Que de détails passés avant inaperçus,aigus superbes et basses bien controlées.Je ne suis pas un expert du son,mais ,à moins d'être sourd,l'apport est incontestable.
Possesseurs de Q5 Pro,ne vous en privez pas !
PS: Envoi sous 4 jours malgré les 15/25 jours annoncé sur la fiche produit,Noel sera donc musical pour moi.
Merci Audiophonics pour votre sérieux.
Godehard B.
Is it snake oil, or does it make an audible difference?
Does it make sense to add a 270 Euro power supply to your IntelNUC-based music server? I was not sure until I tried. The answer is a resounding (pun intended!) YES. The music is less anemic, more authoritative, especially due to a more robust base foundation. Worth every Cent, highly recommended.
Jean-Luc B.
LPSU 1000
Bonjour , elle dépollue le réseau d'une très belle façon !
Cela laisse le chant libres aux micros détails et vous donne de l'épaisseur dans la musique .
Super , je recommande !
arno p.
Absolutely Great Power Supply
Good quality, Built like a tank, stable low noise voltage and plug-and-play for my ROON Nucleus.
Ross B.
Excellent build quality, performance and value for money
I bought the power supply for a NUC that is the core for my Roon setup that uses an Innuos Zenith II as a bridge and an Auralic Vega DAC. Music is stored locally on both the NUC and the Zenith II and I mainly use Qobuz for streaming content. When unpacking the item the first thing I noticed was how substantial and well build it is; definitely built to last. In use it has had a positive impact on the finer details of the sound of my system. The noise floor seems slightly lower allowing for even better resolution of the fine details of the music. Bass seems better resolved and the separation of voices and instruments in all genres of music is more palpable. There also seems to be more richness of tone colour with the nuances of individual performers more apparent. I highly recommend this product as an excellent value for money addition to any NUC based music system.
 (3)
GABRIEL F.
excellent
magnifique coffret, très bien fini, dans un emballage à sa taille. Le poids surprends, gage de qualité pour le profane. Utilisé pour alimenter un Intel Nuc dédié à la musique. Mon intellect est très satisfait de savoir que ce petit ordinateur si puissant est correctement alimenté par un courant filtré et stable. Et je veux croire que la musique en est plus belle. Cet en additionnant des epsilon que l'on arrive au grand son.
Daniel A.
An excellent product
It is an excellent product, which I sincerely recommend to all audiophiles.
I ordered this product a few days ago, and a few hours ago it came to me. Thus, I had the opportunity to test impact on sound quality for 3 power supplies for my Intel NUC:
- Intel NUC stock source (90 W);
- an older FSP source (150 W), significantly larger than the above;
- this linear power supply.
My setup is very simple and straightforward: Intel NUC with Roon ROCK, connected to the internet (for Tidal) through the router, and connected by direct Ethernet cable to the DAC (which is included in the amplifier). Intel NUC also has an SSD with my local music library (normal FLAC and studio master).
Each of the 3 power sources has different results in sound quality.
By far, the best results are those of this linear power supply.
 (3)
Arnaud D.
Excellente rapport qualité prix!
Destinée à remplacer l'alimentation basic du constructeur SOtM (dont je possède le lecteur réseau) qui vend sa propre solution linéaire régulée entre 600 € et 1.200€!
L'ensemble des composants sont de (très) bonne qualité avec un câblage interne excellent. Du beau travail.
Je ne mets que quatre étoiles à regret. Le pin de phase est resté dans la prise du cordon lors de la première manipulation. Sans doute un défaut d'usinage de cette pièce indépendant de la volonté d'Audiophonics.
Pour gagner du temps, j'ai changé moi-même le connecteur avec un modèle un peu supérieur.
