Noel C.
Andrea T.
excellent
Rien de spectaculaire...
Vasileios K.
A great dac for the money
PANGEA AC-14SE MKII Câble secteur triple Blindage Cardas Copper / OFC 3x2mm² 1.5m - avis - Il y a 21 avis.
Guus G.
Great value for money!
I orderd the AC-14se mk2 since I previously ordered the AC-14 and was amazed how a powercable can make that much difference.
The AC-14 gave me the confidence to invest yet a bit more and the AC-14se mk2 delivers. Not as much gain the AC-14 made over the stock cable but enough to be content. Great service from Audiophonics as always.
Jerome G.
Bien sous tout rapport...
J'ai donc switché le cable Stock de mon DAC Audio GD pour le Pangea.
Ca ne révolutionne pas l'écoute, mais pour peu qu'on soit un peu attentif on distingue sans trop de difficulté un upgrade de la qualité du son.
Concernant la qualité de fabrication, je suis loin d'être expert mais on est très loin d'un cable Stock No Name...
A voir avec le temps / Rodage, mais pour la budget, le gain est en ligne avec ce que j'en attendais...
Francisco Javier G.
Excellent quality-price ratio
At this price has no sense to keep the standart stock cable.
Fast delivery from Audiophonics.
Jean-Claude F.
Excellent câble
Installé sur un préamli phono Vida Prima en remplacement d'un câble secteur ancien, bonne amélioration pour un simple câble secteur avec un excellent rapport Q/P. Satisfait
Dragan K.
Instant improvement
For all the theory and science i have read before getting a better power cable i was expecting an improvement. I got this cable for my integrated amplifier. So, to make sure i was not fooling myself :) i did a blind test on my wife by switching between pangea ac-14se mk2 and the stock cable and she also confirmed what i heard as well. The sound stage got deeper(further back in the room), the noise flor went down so more detail was reveled and the overall sound of instruments feels more realistic.
Power cables are not snake oil! A good power cable simply allows your amp to "breathe" properly. Replace all stock cables and your system will thank you for it and reward you with better sound.
jean-françois J.
Parfait
Franchement, je n’y croyais pas.
Ce câble est venu complété mon installation constituée d’un Nad C658, de modules Hypex N400 et des Electra 1028be2.
Et bien, l’apport est indéniable tant sur la clarté que la dynamique ainsi que sur l’immersion sonore.
Pour ceux qui pensaient comme moi que du cuivre reste du cuivre, je n’ai qu’un conseil : essayez par vous même !
christ yannick b.
Très bon câble
Je m'étais trompé à la commande je n'avais pas vu que ce n'était pas pour ampli.
Au premier branchement j'ai cru le renvoyer tout de suite. J'ai inversé sur la prise et je crois que ça s'est mis en phase et là c'était génial.
Branché sur un Atoll IN30 ou un taga harmony hta 700 v2 ça fait un excellent travail. Il a remplacé mon audioquest nrg y3 à 120e.
Un son plus équilibré. Et de la mid bass sur mes elac début 2 bookshelf.
Le câble audioquest avait un meilleur rendu sur les voix mais il manquait cruellement de kick. Là c'est mieux.
Pour le prix je recommande chaudement.
Je vais surement en prendre un deuxième dès que c'est en stock.
Paul G.
Excellent RQP
J'ai déjà plusieurs de ces câbles sur un système HDG.
J'ai acheté celui ci pour tester sur une source Lumin et comme d'habitude il a révélé immédiatement les qualités de la source et l'incompétence du câble raclette original.
Je n'en dirai pas plus car tous les cas sont différents mais chez moi c'est toujours un plus que ces câbles.
Alain L.
Très satisfait
Acheté pour remplacer le câble d’origine du Nad C658.
C’était déjà très bon avant le changement,mais c’est encore mieux maintenant,peut-être un effet psychologique,ce câble est très rassurant.
Jean Michel P.
Pangea AC14 SE MKII
Excellent câble .
Ayant déja un AC14 de base , cette version est nettement supérieure . Un grave qui descend plus bas ,un médium plus fourni , beaucoup de matière et des aigus plus soyeux que le AC14 de base sans sacrifier la définition . Utilisé à l'entrée de ma multiprise Wireworld ,ce câble excelle sur tous les critères . Je rejoins totalement l'avis de Stéphane . Je recommande donc chaudement ce câble secteur très équilibré
Gilles H.
Un réel plus
Associé à un ampli hybride (Kora 90) il apporte une amélioration audible à tous les niveaux. Je le trouve équilibré, rien à retirer à ce prix.
Il est nettement superieur à la version sans "cardas" du modèle C7. Il n'est certes pas extraordinaire mais pour le prix il est imbatable. Le premier pas assuré dans l'univers dispendieux des câbles d'alimentation pour ceux qui doutent.
Cyril s.
Bluffant
J'avais déjà acheté 2 câbles de cette marque pour mes sources (DAC REGA et Streamer Bluenode 2 et j'avais ressenti une amélioration substantielle.
Mais là, avec ce câble sur mon ampli Creek evo 2 c'est... bluffant. Sachant que je me suis trompé ayant acheté ce câble "typé source" au lieu de celui "typé ampli de puissance" (PANGEA AC-9 MKII Câble secteur triple Blindage OFC / Cardas 3x6.6mm²). Je l'ai malgré tout testé et adopté ce câble en 2mm² de section seulement. Détails, scène, dynamique...cela "respire" et je redécouvre ma discothèque. Je suis le premier surpris sur l'importance des câbles secteurs au final, j'étais vraiment sceptique. Est-ce le fait que dorénavant toute la chaîne alimentation secteur est équipée du même type de câble que l'amélioration est aussi sensible ?
Le fait est que le résultat est là. Pour mon usage et puissance demandée par mon ampli, ce câble semble bien suffisant, après pour des amplis très puissants / écoute à puissance très élevée ? Ceci étant dit, je ne suis pas sûr que le câble livré de base avec l'ampli soit plus épais...
NB: avis au bout de 3 semaines d'écoute intensive.
Jean Luc m.
Satisfait
En remplacement du câble d'origine sur un Audio gd dac 19.
Premières impressions,je constate un meilleur respect des timbres (moins de colorations),amélioration des silences entre les notes,écoute apaisée(aucunes agressivités),parfait sur système un peu dur ou agressif dans le registre médium.
Par contre, pas noté d'amélioration au niveau définition
et dynamique,sur ce dernier point j'ai même la sensation que ce câble et peu trop sage.
Ces impressions sont données après un temps d'écoute relativement court,après je suppose qu' avec le temps ce câble va encore s'améliorer,constat souvent relevé suite à
l'achat de matériel de qualité.
Un point positif sur la qualité de fabrication et la robustesse car à la prise en main on l’impression de pouvoir tracter un bus avec.
Un bon point à Audiophonics pour la réactivité,commande traitée rapidement et livrée idem.
Je voudrais féliciter Audiophonics d'exister car je ne connais pas de site de vente en ligne de matériel électronique ayant autant de choix,ou l'on trouve des produits
qu'il est difficile de se procurer sur le marché ,surtout de qualité audiophile.
Attila R.
Amazing value, highly recommended!
I have tried a few cables in my system and although I am not a fan of power cable upgrades it was obvious I need to buy proper cables for all equipment to maximize its potential. This cable seemed to be the right value for the price in all aspects.
The chinese cable I used seemed to work way better than the factory supplied one. Then I changed to mid tier Isotek cables (same gauge as the AC14) and although it prooved to be a decent upgrade giving more detailed sound, it seemed to restrain the bass register for some reason.
Now that I have changed the cables to the Pangea, I have even more detail (in the highs too) and surprising amount of improvement in the bass register. It also seems like the stage is deeper a tiny bit. I do not wish to upgrade to anything more as I believe it really gives a chance to my Arcam and Primare integrateds and phono preamps to show their full potential.
I am truly happy with this purchase and Audiophonics.
alexandre s.
Profondeur d'écoute et détailles améliorés
Meilleur profondeur d'écoute et des détailles plus prononcé, branché sur un Dac Heed Abacus, le PANGEA AC 14SE est une valeur certaine si vous voulez libérer votre source !
Fabien A.
suprenant
J'ai acheté ce câble voila plus d'un an pour mon dac audio-gd et après un rodage d'une 30 aines d'heure j'ai obtenu un gros gain sur la spatialisation, profondeur d'écoute et on gagne une certaine chaleur dans les écoutes, sans doute du à une bonne tenue du medium-grave.
J'ai eu l'occasion de tester ce câble sur d'autres systèmes hifi chez des amis et toujours un gain sur les points cités plus haut.
Un rapport QP vraiment très intéressant pour qui souhaite s'équiper qualitativement sans se ruiner.
Jorge S.
Exactly as advertised
I've just connect it, therefore I'm not certain of any improvements in sound, but I'm a skeptic, so 4 stars.
The major reason to buy this cable was the quality of the wire and the plugs and, mainly, the isolation regarding RFI and EM interferences.
Cyril s.
pour mon DAC REGA
Acheté conjointement avec le PANGEA AC-14SE MKII C7 Câble secteur triple Blindage OCC 3x2mm² 1.5m.
Dubitatif sur l'impact des câbles secteurs surtout sur les sources, je ne le suis plus. Meilleurs présence / détails et dynamique.
Christophe C.
Câble de qualité
Câble de bonne qualité de fabrication. Malheureusement très rigide.
Je l'utilise sur mon lecteur CD Primare et sincèrement je n'ai entendu aucune amélioration ou dégradation sonore par rapport au câble d'origine.
Jean Louis L.
Un des tous meilleurs choix !
J'ai mis ce câble sur mon ampli QINPU A6800, puis lorsque j'ai entendu ce qu'il permet d'entendre, sur le DAC AUDIO-GD 11.32 et sur l'interface digitale USB BREEZE U8 (version 3 avec le transformateur Talema et les horloges TCXO Or).
A chaque fois, après 2 ou 3 jours, le résultat est sans appel et la différence avec un câble secteur ordinaire nettement audible, l'image et les timbres y gagnent nettement.
Ce que j'apprécie particulièrement, c'est leur équilibre. Il ne gonfle aucun registre; pas de surbrillance de l'aigu ni de grave pâteux. C'est équilibré et c'est ce qui leur permet d'être à l'aise dans tout système équilibré.
C'est peut être l'interface USB BREEZE qui en profite le plus.
A ce prix, il est pour moi, dans sa version SE, sans concurrence !
Stéphane C.
AC 14 SE MKII
Bonjour,
J'ai reçu mon AC 14 SE hier matin. Merci à AUDIOPHONICS pour une livraison en express certes, mais très rapide commandé jeudi soir , livré samedi matin Bravo!!
Concernant le câble j'ai déjà un AC 14 mais le SE MKII va plus loin. C'est plus fluide ,plus équilibré avec plus de matière.
Ce câble possède un rapport qualité prix performances , tout à fait étonnant . Nous pouvons toujours trouver mieux mais à quel prix !!
Encore merci à AUDIOPHONICS et BRAVO à PANGEA.
Cdt.
Stéphane.
